HELP! just got seibon cw kit...
Old Mar 4, 2008 | 04:00 PM
350zWhite04's Avatar
350zWhite04
Default HELP! just got seibon cw kit...
just got these in today.. and they have no holes for bolts....??? how did you guys install these?? how did you drill the holes?
Old Mar 4, 2008 | 04:17 PM
onedirtyz's Avatar
onedirtyz
my car is dirty
superglue.
Old Mar 4, 2008 | 04:28 PM
kirradude1025's Avatar
kirradude1025
cant see pic, and if there is not one...u need one!
Old Mar 4, 2008 | 04:51 PM
Concave's Avatar
Concave
my front bumper came with no holes but the body shop made holes in OEM places.
is this kit a lip kit? if so, my last lip kit, i had to make my own holes as well so i could screw them into the wheel well on each side (2 holes each side) and i used 3m double sided tape in the middle. this seems to be the standard that most people use.
Old Mar 4, 2008 | 05:05 PM
350zWhite04
CF didnt crack as you drilled??? how did you do it? starting with a small bit?? and bigger?
Old Mar 4, 2008 | 05:07 PM
Concave's Avatar
Concave
shoot, i only used polyurethane.
sorry man. guess my help was only limited. hopefully someone will help you out with the carbon fiber portion.
I have heard people put tape on top of the carbon fiber before drilling so lessen the "damage"
try searching about people who have drilled hood pins into their carbon fiber hoods. it should be the same method.
Old Mar 4, 2008 | 05:17 PM
SpoilsofWar's Avatar
SpoilsofWar
I had to drill 20 some holes into my CF hatch to attach a lexan rear window, no problems.
Use a step bit, or drill a small pilot hole and work your way up with progressively larger bit sizes, you will be fine. Also, let the bit do the work, dont apply much pressure to the drill.
Old Mar 4, 2008 | 06:08 PM
007gt's Avatar
007gt
genuine c-west lips come with holes
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
phunk
Jun 15, 2005 09:57 PM
hyuk81
Nov 8, 2004 05:23 AM
xXVanquishXx
Jul 9, 2004 12:21 PM
