AeroCatch Hood Latch Users
Old Mar 20, 2008 | 04:42 PM
Agentman03's Avatar
Agentman03
Default AeroCatch Hood Latch Users
How About Some Under the Hood Pictures of The Stud Assembly hookup and up thru the Bottom of the hood Pictures .. Sorry If the internet 350z police Tell us go to a differrent thread location .but would like some installation ideas .Also any Issues with the lineup of the angle of the hood, or special brackets would be Appreciated ... Putting them on a Viper Hood ...
Already did a search ...
Thank's in Advance ..
Old Mar 26, 2008 | 01:31 PM
WSchli1672's Avatar
WSchli1672
I am also wanting to see under the hood pictures of the Stud Assembly and the latch-hood it itself, as I'm wanting to do mine now. If anybody can put some pics in or even pm me the pic's as I need to see to get an idea on where to cut on the hood underneath. Already have my oem hood off and the CF TS Hood on, only wanting to see how anybody has done theirs.
Thanks also in advance.
Old Mar 26, 2008 | 06:22 PM
GWAPITO69's Avatar
GWAPITO69
here's mine. underhood is a little dirty. I kinda messed up on the alignment when I drilled the hole on the hood that's why I have to make a bracket for the stud. My suggestion is take your car and hood to a reputable shop that can do it.
Attached Thumbnails AeroCatch Hood Latch Users-img_0041.jpg   AeroCatch Hood Latch Users-img_0043.jpg   AeroCatch Hood Latch Users-img_0044.jpg   AeroCatch Hood Latch Users-img_0042.jpg   AeroCatch Hood Latch Users-img_0040.jpg
Old Mar 26, 2008 | 08:45 PM
WSchli1672's Avatar
WSchli1672
Excellent pictures of the studs mount. Could you "Please" post some pictures of the hood (underneath)? Want to see where you cut and how it looks. I do have a shop that will do it, but they are also wondering of the under hood. That would be perfect for a finishing touch. Thanks again too.
WS
Old Mar 26, 2008 | 10:19 PM
GWAPITO69's Avatar
GWAPITO69
1st picture passenger side and 2nd pics driver side 3rd what it looks like when its close. Dont mind my front bumper I have to get it repainted
Attached Thumbnails AeroCatch Hood Latch Users-img_0045.jpg   AeroCatch Hood Latch Users-img_0046.jpg   AeroCatch Hood Latch Users-img_0035.jpg
Old Mar 27, 2008 | 02:28 PM
WSchli1672's Avatar
WSchli1672
Thanks, I really appreciate it. I've already sent the pictures to the body shop that will do the installing. I don't think I will try that, as my hands would probably give an extra air hole or two or three.....before I finished. Hopefully this will satisfy them. Thanks again.
Agentman, that should help you out also.
Old Mar 28, 2008 | 07:05 PM
Agentman03's Avatar
Agentman03
Thank's Also , Those Brackets You Made also seem to somewhat Take Care of The Angle of the Hood in Relation to the stud issue that never seemed to be defined on earlier post's .. thanks again ,,,
Old Mar 28, 2008 | 07:15 PM
Agentman03's Avatar
Agentman03
Also noticed that the bottom side of the hoods on these aerocatch mods seem to cutout and remove a " large section " of the underside support bracing of the hood , instead of cutting it out the same as the top side cutout area .. Asuming this large cutout area must have interfered with the pin lineup or something ??
Old Mar 28, 2008 | 08:06 PM
GWAPITO69's Avatar
GWAPITO69
the large cutout area on the underside of the hood is a must for you to hold the bolt with a socket when you start tightening those hex nuts on the latch.
Old Mar 29, 2008 | 08:34 PM
WSchli1672's Avatar
WSchli1672
Mine done yesterday. Also that will not do much damage at all as to the cutouts, as it's still sealed all around, just a center piece. Talked with the company that sells them, and most all hoods are done the same way, unless you can order the hood with some special mold, which he had pictures of a different CF Hood for a another car where it was made for it. Don't know where he got the hood from, but must have special ordered it that way they figured. He stated it was special ordered though, and I have the pictures on my email, just don't know how to put them on here. I took them to the shop, and mine was done same day. Now I'm having some fiberglass covers made to cover the cut to make it look natural. Thanks again for your pictures, they helped to make it clear about the cut needed.
Old Apr 3, 2008 | 11:46 AM
bluezup's Avatar
bluezup
can someone tell me what the 2 rubber pieces are used for that comes with the aerocatch? can you take a picture of what it should look like?
Old Apr 3, 2008 | 02:52 PM
Agentman03's Avatar
Agentman03
Default AeroCatch Hood Pins
Rubber Shock Spacer ? This Picture is not a real good sample for the 350z but gives you the idea .. Not a lot of space between the hood and brace on the z but can always cut to size ??
Old Apr 6, 2008 | 06:54 PM
Nukiz0r's Avatar
Nukiz0r
Subscribing for when i get my aerocatch.
Old Apr 7, 2008 | 05:31 PM
bluezup's Avatar
bluezup
so that rubber piece is suppose to stop the hood from going lower? if thats so then that means you took off your oem latch for the hood?
can really tell what its for even from the pic
Old Apr 7, 2008 | 05:38 PM
Try&keepup's Avatar
Try&keepup
subscribed
Old Apr 7, 2008 | 06:36 PM
eltness350's Avatar
eltness350
The Untouchable
the rubber pieces r a "hood bump" ..its easier to adjust the height of your hood with a rubber spacer since not all hoods sit at the same height...since they figure its goin on a aftermarket hood/aftermarket body kits might affect adjustment.......
350Z_Al
Oct 29, 2020 07:44 PM
