wiring 2006 tail lights?
Old Mar 27, 2008 | 08:42 AM
halfass872's Avatar
halfass872
Default wiring 2006 tail lights?
I'm putting in my 2006 tail lights today. And i remember reading somwhere a while ago that there is some modifications when putting them in an '03. I can't seem to find the link for it. Any suggestions or a link would be appreciated!! Thanks!!
Old Mar 27, 2008 | 08:53 AM
usmanasif's Avatar
usmanasif
I haven't had to do this myself, but IIRC, it is PnP. The 03-05 lights have an extra harness that the '06+ do not so you only plug one harness into each and it works. You may need to confirm that yourself by popping one side off.
Old Mar 27, 2008 | 08:58 AM
halfass872's Avatar
halfass872
thanks!
Old Mar 27, 2008 | 09:00 AM
BlackWidowZ's Avatar
BlackWidowZ
Just Plug and Play. Just plug the main/bigger connector and tuck away the smaller connector. There's also alot of DIY on this thread about upgrading from 03 tail lights to 06 tails. GL
Old Mar 28, 2008 | 08:47 AM
themadhatterxxx's Avatar
themadhatterxxx
NOT just plug and play. I had to shave off the ridges with a dremel on the harness that comes from the car, to be able to have it fit the harness on the taillight.
Old Mar 28, 2008 | 08:54 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
If he has the OEM 06+ LEDs he does NOT have to do anything extra.
Now if he had the JDM LEDs (like the ones you have) then YES the ridges need to be shaved.
Old Mar 28, 2008 | 09:01 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
+1 took me 15 mins to installed my 06 rears on my 03 Z. Here's the instructions:
1) Open your trunk and pop out the snap caps to the bolts.
2) Take out 3 bolts on each side.
3) Pop the lights out. (Be careful not to break the plastic tabs)
4) Pop the harnesses off.
5) Connect the large harness only on the 06+ lights on your 03-05 Z. and leave the small harness off. (Might be a good idea to tape up the small plugs with electrical tape)
6) Put everything back in reverse order.
No shaving or ridges need to be modified. 06 lights sit flush like the old ones.
Old Mar 28, 2008 | 09:14 AM
halfass872's Avatar
halfass872
Yep Karl is right. Just tuck away the second plug, and that's it!
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
