carbon Fiber Pillars
Ah, did your use that activator. If so, you melted it and have to recondition and paint it or replace it.
If not, WD-40 works well.
Also lighter fluid, but rinse after use.
Goo gone as someone mentions below works but, be careful leave it on too long and it will haze that shiny black surface and may even melt it a bit. Depends on the material and how hard it is. "I'd have a bad experience."
could soak it in hot water and rub it off with your finger's. .may take a while but it works well. .a penetrating grease or wd40 may work good as well, but dont hit it with any type of carb cleaner or nething. .might damage the coating. see if u can use a razor blade and slide it under and scrape it off nice and easy. .
Originally Posted by Bumpinjeep
What about using a blow dryer to heat it up and just peel it off? Good call on taking it off too thats ricetastic.
Originally Posted by DraGonAlchemist
if you heat carbon fiber. .ASSUMING it's real. it will be able to bend easily and may get reshaped if not careful, so i'd say blow drier's out!
http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
3M adhesive removal works pretty well when I tried to clean the sticky stuff when replacing the weather strip
Originally Posted by nonshalant1
I need to replace my carbon fiber trims on my pillars, but would like to know the best way to remove the old sticky residue from the old ones. Any suggestions?
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
