G-tech accelerometer
Old May 11, 2008 | 05:22 PM
Chad68's Avatar
Chad68
Default G-tech accelerometer
Is there anybody using one of these? They seem like they would be a fun thing to play around with.
If anybody has one, is it possible to install it with the LCD display facing up (towards the roof) instead of using the windsheild suction cups?
Guess I could just intall it in the cubby I don't really use, if it needs to be upright.
http://store.summitracing.com/partde...5&autoview=sku
Old May 11, 2008 | 06:25 PM
PDX_Racer's Avatar
PDX_Racer
I've got a GTechPro RR (which allows you to download the data to a computer). The SS requires that you do everything on the device.
It doesn't have to mounted in any particular orientation. The first acceleration allows the device to recognize what is "forward."
Old May 12, 2008 | 07:36 AM
james840a's Avatar
james840a
I have one too, GTechPRO RR...
I have to start using mine again been awhile
Old May 13, 2008 | 07:05 AM
chopperman's Avatar
chopperman
I heard that these units arent that accurate. Is that true? How accurate are they?
Old May 15, 2008 | 05:15 PM
Chad68's Avatar
Chad68
where did you guys mount it, with the windshield cups or permanent mount?
I really don't want to mount it on the windsheild but want a cleaner look and try to hide the cord the best I can.
Old May 15, 2008 | 05:44 PM
Jim@Showstoppers's Avatar
Jim@Showstoppers
Those G-techs are garbage, we did some testing on campus with our FSAE car with the G-tech and it was off by quite a bit.
Old May 15, 2008 | 11:25 PM
PDX_Racer's Avatar
PDX_Racer
My mount is at the top of the windshield, next to the mirror.
I take care of mine and don't throw it around (IOW, I treat it like a precision instrument). If mine is off, it's not off by much -- and others who are comparing accelerometer and GPS-calculated data are finding that theirs are fairly close.
Old May 16, 2008 | 06:15 AM
james840a's Avatar
james840a
Plus when you enter the car weight, dont go by the tag on the side of the door. Go and have your car weighed at a weight station to get an accurate weight. Is it accurate as a Dyno,, No. But will give you a good idea of a range yeah.
Old May 16, 2008 | 01:11 PM
Chad68's Avatar
Chad68
That's what i was thinking too. For best results need to find a truck type scale and weigh the car with half a tank of gas and with drivers weight added too.
I don't care so much about the HP and torque readings, which I'm pretty sure would be noticebly off, due to the way it calculates them. More interested in the other things 60 foot times, 0-60, 60-100 1/4mile times and cornering G's.
Phil-350
Jan 29, 2006 07:47 PM
PerfZ
Apr 4, 2005 01:47 PM
mcduck
Dec 31, 2003 08:39 PM
raceboy
Aug 21, 2003 06:50 AM
