Wheel Spacers?
Old May 20, 2008 | 10:54 AM
TBDesigns's Avatar
TBDesigns
Default Wheel Spacers?
I need wheel spacers i'm just not sure what size to get I have 19" MMR rims and the seller said he thought the offset was what is in my sig. Not to sure though. Any help?
Old May 20, 2008 | 10:56 AM
JasonZ-YA's Avatar
JasonZ-YA
I would say 25 mm all around...
Old May 20, 2008 | 11:52 AM
noodleman's Avatar
noodleman
what's the width of the rims?
Old May 20, 2008 | 12:06 PM
TBDesigns's Avatar
TBDesigns
Dunno
EDIT: Just pulled this info off a site selling them..
Title: 19 Inch Nissan Infiniti MRR GT1 Wheels Rims
Diameter: 19 Inch
Width: 8.5 Front and 9.5 Rear
Offsets: ET.35 front and ET.38 rear
Bolt pattern: 5x114.3
Finish: Black w/ Machined lip
Fitment: Nissan 350Z
Old May 20, 2008 | 12:07 PM
iStan's Avatar
iStan
ZR
Take your wheels off (1 front 1 rear) and look for markings for sizes. If you can't find any, bust out the tape measurer.
Hmm, 8.5F 9.5R it looks like
Per MMR (I just got off the phone with them) +35 FR
^Um, er. Sht. Whatever 3 mmm is like the size of CTs ****, so no biggie (harhar)
Old May 20, 2008 | 01:42 PM
apsttRDSTR's Avatar
apsttRDSTR
Default Info For You
Hey Tim
I just finished putting Kics Project Spacers 10mm Front & 20mm Rear on the car. I have the O.Z 3-peice Supperlaggera's F19x9.5 +29 /R19x10.5 +34 with Nitto Invo Front 255/35 Rear 305/30 tires.
I had to roll the rear fenders to get the wheels/tires flush with the outside of the fender well. With the suspension fully compressed the tire to fender clearance is about 3 to 5 mm at the top. I used the hub centric rings for the rears even though they said that it was not required. The wheels seemed to be a lot easier to line up with them.
As for the fronts I had to trim my stock studs to allow for wheel to spacer clearance. This was not that hard and I only trimmed 5mm off the stock studs. The hardest part was growing enough bawls to cut the studs. Finished product looks awesome and the wheels are slush with the fender wells.
I could have gone with 25mm or 30mm with a stretched tire setup, but I need the rubber.
Traction = Good
Old May 20, 2008 | 01:48 PM
TBDesigns's Avatar
TBDesigns
Originally Posted by apsttRDSTR
Hey Tim
Traction = Good
Damn I don't want to do any rolling or anything.
Old May 20, 2008 | 01:50 PM
iStan's Avatar
iStan
ZR
The rolling is because of the 305 in the rear. Stick with 275 down, you'll be fine.
Old May 20, 2008 | 01:52 PM
TBDesigns's Avatar
TBDesigns
ill have to check what my rears are I forgot
Old May 20, 2008 | 02:03 PM
apsttRDSTR's Avatar
apsttRDSTR
Default ___
The 305's fit and did not rub before the fenders were rolled. After the C-West side skirts went on the wheels looked to "sunk in" in the fender wells. That is the reason for the spacers. I wanted a more agressive stance with the wide rubber. I would go 315 or bigger but the rim is a 10.5" and 305 is about the widest I can go with out the tire looking stupid on the wheel.
Old May 20, 2008 | 03:13 PM
TBDesigns's Avatar
TBDesigns
LOL I don't remember what size they were
Old May 20, 2008 | 03:15 PM
iStan's Avatar
iStan
ZR
I doubt it's over a 275.
Old May 21, 2008 | 04:54 AM
noodleman's Avatar
noodleman
Originally Posted by TBDesigns@CiNcity
Dunno
Diameter: 19 Inch
i'm running 19x8.5+10 (245/35) and 19x9.5+9(275/35) and had a very slight rub in the rear.
if i were you, i'd get 25 mm's all around. to make it 8.5+10 and 9.5+13, and you'd probably be ok with rubbing.
Old May 21, 2008 | 07:42 AM
TBDesigns's Avatar
TBDesigns
arrr don't know what to do. I have some tein s springs coming to so I'll be a inch lower
Old May 21, 2008 | 07:48 AM
noodleman's Avatar
noodleman
at 25mm's all around, you wont' regret it. I only had light rubbing with my set up. I'm pretty certain that you wont' rub with 25mm spacers.
Old May 24, 2008 | 03:38 PM
500HPZ's Avatar
500HPZ
Vendor - Former Vendor
305 on a 10.5" wheel? Daaaayyuuuuuuum muscle car style. How about some 275s on a 11" wheel.
Old Jul 23, 2008 | 12:16 PM
TBDesigns's Avatar
TBDesigns
Looking to buy some 25MM spacers!
Obadabot
Jun 18, 2023 11:31 PM
