horizontal headlamp/ headlight adjustment
Old Jun 25, 2008 | 04:27 AM
inanabhay's Avatar
inanabhay
Default horizontal headlamp/ headlight adjustment
hi
i've searched but don't seem to find result in title
i have already adjusted my headlamps / headlights up to the desired level
however, when i take sharp/ 90-degree turns, i turn into darkness as there is not enough light - i need to adjust the beams horizontally
kindly advise how to do so
TIA
Old Jun 25, 2008 | 04:38 AM
Z04's Avatar
Z04
you know that by adjusting them up you threw off your side view, so basically you created your own problem. my suggestion is to set them back to within specs and your problem should go away. also oncoming traffic will thank you as well.
Old Jun 25, 2008 | 04:52 AM
inanabhay's Avatar
inanabhay
wow
amazing reply
thank you kind sir
Old Jun 25, 2008 | 05:28 AM
Z04's Avatar
Z04
not really sure if that is supposed to be a sarcastic reply or a honest one, but what i posted is true. unless you know what you are doing and have the proper tools, your headlight aim will always be off.
Old Jun 25, 2008 | 05:56 AM
inanabhay's Avatar
inanabhay
clever
they are within spec - originally, they were too low - something which i'm sure you must have read that lotsa people are complaining about
i've even considered fitting spot lamps angled out but would like to first try and adjust them sideways
(there's others also asked same question on other forums without replies)
so, if you know how to do that, kindly let me know
Old Jun 25, 2008 | 09:29 AM
redlude97's Avatar
redlude97
How were they too low to start with? How did you measure it and make sure its within DOT specs?
Old Jun 25, 2008 | 09:49 AM
Z04's Avatar
Z04
from the way he is talking, i think he has no clue to what you are even saying at all.
Old Jun 25, 2008 | 09:54 AM
Spork's Avatar
Spork
My stock headlights were aimed too low IMO. I couldn't see far at all.
Now I adjusted them higher, to around 24" IIRC, and everywhere lights up perfect.
Old Jun 25, 2008 | 03:54 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
to answer your question there is no horizontal adjustment
Old Jun 25, 2008 | 10:41 PM
inanabhay's Avatar
inanabhay
thanx
Old Oct 28, 2010 | 03:47 PM
OldManZ350's Avatar
OldManZ350
Where the H is the Vertical Adjsutment? I have a manual, and still can't see it.
Can anyone describe how to find the location? and is it a phillips head screw?
Thanks......
Old Oct 28, 2010 | 07:33 PM
Kwame's Avatar
Kwame
Thanks......
350z Headlight Adjustment
Old Oct 28, 2010 | 07:38 PM
DaProdigy's Avatar
DaProdigy
Originally Posted by Kwame@z1Auto
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
