Turn Signals On While Driving?
Old Jul 27, 2008 | 10:58 AM
Sergio8A's Avatar
Sergio8A
Default Turn Signals On While Driving?
Sorry to start a new thread but i cant find it anywhere? does anybody know how to keep the front turnsignal bulbs on while driving and then blink when u turn the signal left or right? ive seen this done but have No F#$&#in idea how to?
Old Jul 27, 2008 | 11:15 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
use a NORMALLY CLOSED relay to pass 12v to the bulbs. Then use the original 12v power wire as your signal wire to the relay.
When you turn on the car, the lights will illuminate. When you hit the blinkers the relay will cut power to the lights when theyre supposed to blink normally. youll still end up with blinking tho.
Old Jul 27, 2008 | 11:34 AM
Sergio8A's Avatar
Sergio8A
damn I wish their was a DIY with pics?LOL where can I get a normally closed relay ? What does it look like ?thanx for the help
Old Jul 27, 2008 | 12:12 PM
Spork's Avatar
Spork
Where have you seen this done?
06+ headlights have the turn signal on all the time as DRLs IIRC.
Old Jul 27, 2008 | 12:48 PM
Sergio8A's Avatar
Sergio8A
i have an 08 enthusiast?They Dont Stay on?ive seen an 08 Grand Touring and they still dont stay on?
ive tried asking this guy but no reply yet?see how his turn signals stay on with the fog lights!
Old Jul 27, 2008 | 02:32 PM
sintaxeror's Avatar
sintaxeror
It depends on how the signals are wired, you will have to investigate that.
I suspect the one side is grounded, the other side is connected to the blinker signal which flashes between ground and 12V when the blinker is blinking.
If this is the case, all you have to do is change the side that WAS continuous ground to switched(ignition) 12V.
Clear as mud?
Old Jul 27, 2008 | 02:36 PM
chicagokid's Avatar
chicagokid
Originally Posted by Sergio8A
I want those eye lids..............
Old Jul 27, 2008 | 02:41 PM
gregom's Avatar
gregom
That's a pretty nice looking Z... whos Z is it I wanna see the mods list.
Old Jul 27, 2008 | 03:15 PM
crg914's Avatar
crg914
This is how you should wire it up. Fairly easy. The top picture is how it is currently wired. The bottom picture is how you should wire it. Take the power wire for the lights, on my 07 it's green with a white tracer and connect it to the control side of the relay (pin 85), and ground the other pin for the relay coil (pin 86). Run B+ (ignition switched) to the relay (pin 30) and run wire from relay (pin 87a) to the light where the green/white wire used to be. Done. There will be another pin on the relay number 87, just leave that one alone, it is not needed. These numbers are assuming you use a standard Bosch relay.
Light will have power at all times, and when the turn signal is turned on, the flasher will power the relay, which will cut power to the light. It will blink opposite the rear blinker, but still accomplish your goal.
See attached for pic.
EDIT*** Without being able to personally perform these steps, I take no responsibility if something goes wrong due to inexperience, or any mistake you may make. Mod at your own risk.
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
samansharif
Sep 25, 2015 12:31 PM
