Filling holes question
Old Aug 1, 2008 | 07:40 AM
Spoiled Z's Avatar
Spoiled Z
Default Filling holes question
I want to debadge the rear and I was wondering if I take off the rear wiper if that would work as well. My friend said the whole is too big to fill?! What do you guys think. I bought something at homedepot to cover the hole but since Im having a shop fill the holes on the emblem I was thinking I might as well do the rear wiper. Thanks
Old Aug 1, 2008 | 02:43 PM
johzp's Avatar
johzp
I might do the same thing when i debage and paint...anyone with advice?
Old Aug 3, 2008 | 07:42 PM
Eazzy's Avatar
Eazzy
Layer of Fiberglass on the underside---Then the filler that should be used on all applications....Evercoat EVERGLASS.TM. Short Strand Fiberglass Reinforced Body Filler
Its reinforced with Kevlar and Waterproof
Old Aug 3, 2008 | 08:05 PM
ndilo21's Avatar
ndilo21
There are wiper plug kits, do a search. They cost like $25 and you dont have to worry about fiberglass and paint.
Old Aug 3, 2008 | 08:14 PM
350ZTheStandard's Avatar
350ZTheStandard
Really I can get raped for $25.00 dollars for the same plug I can get at Home Depot for $1.99. Where???? I don't know about where you all
live but it rains where I live, & I like looking out the rear glass. But that just me.
Old Aug 3, 2008 | 08:15 PM
SuperBlack350z's Avatar
SuperBlack350z
i would never use just fiberglass. I would have to weld it shut but it's very expensive to do it right since warping can occur. That's the correct of doing it. Half *** job would be using fiberglasss and bondo.
Old Aug 3, 2008 | 08:26 PM
Eazzy's Avatar
Eazzy
Fiberglass is simply a back up for the filler....a sturdy, solid place for which the filler will sit. DO NOT use "Bondo" use what I suggest. I suggest this because I do this with zero failures.....It does not shrink, it does not crack, it is highly adhesive, it is very strong, it is easy to shape, it is waterproof, it is expensive, so "Joes" paint and Body dosnt use it
I learn from my failures and I pass along what my failures have taught me works
Old Sep 16, 2008 | 11:14 AM
Germanguy's Avatar
Germanguy
Default Help searching plug for bottom and squirter!!!
Someone can give me a link, where I can buy a rear wiper remove plug + a squirter plug? Like these http://www.gotplugs.com/350z%20V2%20Kit.htm
but he doesnt write back.
Thanks!!!!
Alex.
Old Sep 17, 2008 | 05:33 AM
Germanguy's Avatar
Germanguy
^bump, please help!
issyz
Jul 2, 2017 03:04 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
350z82
Oct 1, 2015 06:25 PM
