Z Hitch...whose got one
Old Sep 2, 2008 | 12:02 PM
island03z's Avatar
island03z
Default Z Hitch...whose got one
There was a post a while back about someone that made a Z hitch that hid under the rear bumper when not in use. Searched all those threads for people that made them and tried contacting them and it turns out no one I contacted still makes them anymore. Does anyone know where I can get one?
Old Sep 2, 2008 | 01:08 PM
mw9's Avatar
mw9
just bought mine here a few weeks ago, part # 11493
http://www.hitchsource.com/
Here is a good link to pics:
https://my350z.com/forum/exterior-in...nt-code-2.html
post 23 and 26 are pics of my setup
have any questions let me know
Old Sep 2, 2008 | 01:34 PM
TheBroberts's Avatar
TheBroberts
Jason Z-ya Has One Search For Him
Old Sep 2, 2008 | 03:02 PM
TTwinTTurbo's Avatar
TTwinTTurbo
Mine has one its an 03.. Very irritating as I have to take off the whole rear bumper to gain access to the bolts holding the tow hitch on. I have no idea why someone would put 20 inch volks and a tow hitch on a 350z...
Old Sep 2, 2008 | 03:13 PM
drinkingmymilk's Avatar
drinkingmymilk
to tow their other set of wheels to the track seems like a logical reason.
Old Sep 2, 2008 | 03:32 PM
racerfreakxxx's Avatar
racerfreakxxx
ehhhh... get a truck and tow the z and put the wheels in the bed of the truck
Old Sep 2, 2008 | 04:54 PM
mw9's Avatar
mw9
Hitch and trailer is pretty easy to do. I would have to buy a truck and then buy a trailer. If a corvette can get away with so can we. I will also be racing in different states, so a trailer is the least expensive way to travel
Old Sep 2, 2008 | 09:08 PM
island03z's Avatar
island03z
That's my reason. The track is an hour 45 minute drive for me.
Old Sep 2, 2008 | 09:18 PM
island03z's Avatar
island03z
That, and I can't afford/ dont need a truck other than for this reason.
Hey Mw9, if you have them can you post pictures of the Z with the hitch hidden and with it ready for use? And if I'm understanding this correctly, you have to take off your rear bumper every time you need to connect your trailer up?
Old Sep 2, 2008 | 09:31 PM
PDX_Racer's Avatar
PDX_Racer
I've got one of Roark's hitches, and it's great -- other than you really do need to have the bumper mounting brackets gusset-welded since they are designed for compression, and the hitch applies tension.
Vertical receiver, so if the stinger isn't on, you don't even know it's there.
I've used mine for carrying my DOT-R tires and race gear to autocross events. It beats having the tires inside the car (especially if, when I get there, it's raining) and the car hardly knows that the trailer (approx. 450 pounds total) is back there.
Old Sep 4, 2008 | 10:36 AM
island03z's Avatar
island03z
Where do I get Roark's hitch?
Old Sep 4, 2008 | 12:59 PM
mw9's Avatar
mw9
Check out post #2, that has all of my pictures and info on the hitch. No, you don't have to take off you bumper, look at my pictures
Old Sep 4, 2008 | 09:10 PM
PDX_Racer's Avatar
PDX_Racer
That was a custom-made hitch. The hitches currently available are similar, but may not have the vertical receiver.
You might check around, there may be people who have one that aren't using it any more.
Old Dec 17, 2008 | 09:16 PM
JasonZ-YA's Avatar
JasonZ-YA
yup, MW9 has it covered in post number two.......
his second link is this thread of mine where i got hitchsource to give my350z members a discount.
here: https://my350z.com/forum/exterior-in...ount-code.html
-J
Old Mar 14, 2009 | 10:39 AM
12AutoX's Avatar
12AutoX
Any reason why this hitch is listed for '04-'06 Z's, excluding '03? I am going to pick one up for my '03. I noticed there are two styles out there; one that mounts below the license plate and another that uses the frame rails. All the ones I've seen mounted are the ones that mount beneath the license plate.
Old Mar 24, 2009 | 11:30 AM
power2rice's Avatar
power2rice
I also have an 2003 350z touring model that uses the curt hitch 11493. I believe the reason why 2003 was not posted anywhere at all is because there was no official 2003 demo test fitment done on that year to confirm. But from all the 350z's I've seen, they all used the 11493, and the g35 used the 11483. I ordered mine from hitchsource and had to put in 2006 as the year in order to obtain the 11493 option.
Old Mar 26, 2009 | 08:07 AM
raduly's Avatar
raduly
I had the same hitch intalled at U-Haul for about $150. Check with them but make sure you stay there and look at what they do. They installed mine wrong and the hitch is right up against my exhaust so there's more vibration in the car. They also dented my Nismo muffler to make it fit.
Old Mar 29, 2009 | 11:42 AM
power2rice's Avatar
power2rice
Some of you might wonder what it looks like with a bike rack on, so here are some pictures of a 2003 350z with the Curt 11493 hitch.
Old Apr 1, 2009 | 05:54 AM
BPRacer's Avatar
BPRacer
What is the difference between the two part numbers?
(I know, 10, right? )
I have an '05 with the bumper tuck mod done. I am wondering if one of these would sit higher up than the other, so it is tighter to the modified bumper?
Old Apr 2, 2009 | 02:22 AM
power2rice's Avatar
power2rice
The 11493 uses the boxed bumper support beam found on the 350z. The 11483 uses the rounded bumper support beam found on the g35. I have NEVER seen them vice versa. Correct me guys if I'm wrong but of all the 350z I've peaked under the rear bumper to see, they all require the 11493 Curt Hitch. Every single one I've checked had the rectangular boxed support beam.
Both 11493 and 11483 sit at the same height, what makes them different is the 11493 has a narrow lower plate, versus the 11483 having a wider plate to accommodate the thicker g35 bumper support beam.
