Replacing rear / front emblems
Old Aug 15, 2003 | 05:25 AM
AndyB's Avatar
AndyB
Default Replacing rear / front emblems
Has anyone replaced the front and rear emblems on a Z?
I am interested in replacing the "NISSAN" logo with a simpler "Z" in a circle logo.
Is there a Z logo badge that is the correct size for those spots? Where can I get them?
Anyone got a picture of this already done?
Thanks in advance.
Old Aug 15, 2003 | 05:49 AM
wren57's Avatar
wren57
They have them at courtesyparts.com. You can buy them in a pair. If you only want to use one, I will buy the second from you, as I am looking to buy just one as well. Thanks.
Old Aug 15, 2003 | 08:21 AM
AndyB's Avatar
AndyB
Default Details...
Are there any tricks to getting the old one off? (Like holes under the emblems?)
Also, will the new ones at courtesy completely cover the same area (in case the paint is damaged during removal?)
Just curious.
I won't be getting em too soon since my Z isn't due to October, but I already have about $400 of accessories in my basement or on order. 8*) (Quick Shifter, seatback organizer, front plate relocation bracket, etc.)
Old Aug 15, 2003 | 09:01 AM
pimp1911's Avatar
pimp1911
I have replaced the front Nissan emblem with the Z emblem from courtsey. Under the front emblem there are 3 pronges that will help you align the Z emblem. To remove the current Nissan badge you can use a hair dryer using (warm air to hot air) to remove the emblem. You are heating up the adhesive under the bottem of the Nissan emblem. And it will allow you to remove it.
Once you remove it you need to clean the area with adhesive remover to make sure it is clean before puting on the new Z emblem.
The rear emblem I havent done. I am still trying to determine if there are 3 pronges under the emblem that will allow you to align it. Some say there is. Some say there isnt and you have to manually center it.
Old Aug 15, 2003 | 09:43 AM
ares's Avatar
ares
Veteran
from pics Ive seen there are 2 holes under the rear. this leads me to believe that you cant simply buy a pair and split them, unless one wants them on front and one on rear.
they are not interchangable.
Old Aug 16, 2003 | 11:10 AM
Anyone2u's Avatar
Anyone2u
Charter Member #82
Here's a picture of the rear deck with emblem removed. BTW the scratches buffed out fine. I removed the "350z" badges as well and just put a "Z" back there (got it from the door "sill" panel).
Old Aug 18, 2003 | 09:50 AM
3rdpower's Avatar
3rdpower
I removed the chunky rear Nissan badge and put on a custom panted Z circle that matches my leman's sunset... it look beautiful
Old Aug 20, 2003 | 05:51 PM
Beaker02's Avatar
Beaker02
Got a pic?
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
hardkicks
Sep 20, 2015 12:28 PM
Alex Tappin
Sep 9, 2015 08:18 PM
