Brighter Headlights?
Old Dec 1, 2008 | 09:30 PM
Konvict's Avatar
Konvict
Default Brighter Headlights?
i have HID's on my 2003 Z but they dont shine that bright... i hate it driving at night and often hit the high beams if no cars around so i can see better
am wondering if i can just get like stronger bulbs? or a diff kit? any recommendations are nice...jsut want more light
thanks
Old Dec 1, 2008 | 11:40 PM
dj.kickz's Avatar
dj.kickz
I upgraded from the same lights you have to 06 headlights with the STI clear lens mod that CinCity offers and its 10x brighter, highly recommended.
Old Dec 2, 2008 | 07:19 AM
robbinsj's Avatar
robbinsj
1,500 - 2,000 to see better at night???? If it bothers you that much and you sleep on piles of cash I also recomend but you can get some improvment buy just buying better aftermarket HID bulbs.
Old Dec 2, 2008 | 07:20 AM
o2sys's Avatar
o2sys
You could also upgrade to a 55W ballast for more output. But i still think the headlight design is the weakest link. I cant stand them.
Old Dec 2, 2008 | 07:26 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
dang, I had regular halogens (cause Im a base Z owner obviously) and got a kit for like 140 and its 5K bulbs. Its bright as hell, brighter than my high beams..
but since you already have HID's, just get new bulbs..
Old Dec 2, 2008 | 07:37 AM
str8dum1's Avatar
str8dum1
or make sure they are aimed correctly. often they are too low making it hard to see past the defined cutoff.
Old Dec 2, 2008 | 07:45 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
upgrade to 55w, and don't look back
Old Dec 2, 2008 | 09:00 AM
dj.kickz's Avatar
dj.kickz
says the guy whos spent hundreds on badges.
Old Dec 2, 2008 | 09:07 AM
Eclipseguy12's Avatar
Eclipseguy12
what type of bulbs do I get for a 06 if I want them to be more blueish.. ?
Old Dec 2, 2008 | 09:36 AM
Thermal1's Avatar
Thermal1
^^ STI mod will make them look better than bluer bulbs
but to answer your question:
6000k is a good white-blue color.
8000k is very blue.
Old Dec 2, 2008 | 10:07 AM
jubes's Avatar
jubes
If you raise the kelvins in your bulbs, you'll get a bluish hue... but you shorten the viewable distance... optimal is 4300k - 5000k for maximized light and distance.
I thought about raising the watts.. from 35w to 55w.. but I found out that in some states it's illegal. So i'd find out about the laws regarding raising watts on the HIDs, unless you don't mind being pull-over.
I'm just speaking from perspective of a driver in California... I know it's different in other states.. IMO.. I would just change the bulbs to stock kelvin with the Phillips brand or if you want... PIAA makes D2R bulbs as well, but I'm not sure if they sold 4300k bulbs or was it higher.. possibly 6000k..
Old Dec 2, 2008 | 10:19 AM
redlude97's Avatar
redlude97
new aftermarket bulbs will most likely make the problem WORSE, not better. Your best option is upgrading to 06+ lights, or getting a new set of philips 85126+ d2r bulbs, which can be found on ebay for ~$50. A new set to replace yours which are a couple years old will likely give you back 3-400 lumens.
Old Dec 2, 2008 | 10:53 AM
quakerroatmeal's Avatar
quakerroatmeal
There are a few things you can do.
Check your beam pattern, you might need to readjust them to aim higher they might be a little too low.
Retrofrit real HID projectors (E55, TL/TSX, S2K, LS430 projectors) into the current housing.
Upgrade to 06+ head lights.
Like the other states, nothing will really beat the cutoff/shine of the oem 4300-5300k output. You might think those aftermarket kits are bright as hell because you have them aimed to the sky and blinding everybody on the road.
Old Dec 2, 2008 | 11:52 AM
Escobar's Avatar
Escobar
All great suggestions, just make sure they are aimed right. If so, then you may want to do the upgrade to 55watt. I highly recommend not going above 6k on the bulb kelvin.
Old Dec 2, 2008 | 12:25 PM
Konvict's Avatar
Konvict
ok i'll have a look and see if they are aimed right.
i wanted cin city to sponsor my car so i wouldnt have to spend so much on their lights lol
Old Dec 2, 2008 | 07:59 PM
Konvict's Avatar
Konvict
ok so the headlights look aligned fine...
where would i get these 55w bulbs from? any specific brand?
and thanks to everyone for the advice and quick responses
Old Dec 3, 2008 | 04:06 AM
Z04's Avatar
Z04
touche' i was going to say that i paid nowhere near that amount for my cincity mod.
Old Dec 3, 2008 | 04:11 AM
Z04's Avatar
Z04
it is 55w ballasts you would need to run the 55w bulbs. the 55w bulb in a 35w system probably would not work. BTW, how clear is your outer housing? that make s a difference in the amount of light that gets out as well. i have seen some 2003's with very dull looking headlight covers.
Old Dec 3, 2008 | 06:43 AM
Ivory's Avatar
Ivory
Let me know when you find actual 55watt rated bulbs.
Old Dec 3, 2008 | 07:12 AM
Z04's Avatar
Z04
sure
http://www.retro-solutions.com/55WD2SKIT.html
DIGITAL High Output 55w Ballasts and 55w Bulbs
they go with the 55w kits.
