Was doing some searching on headlights (HID, etc.)
Old Dec 3, 2008 | 11:08 AM
ohfourzee's Avatar
ohfourzee
Default Was doing some searching on headlights (HID, etc.)
I have an 04 Base, and I read that the 03-05 dont have true projectors? But they have HIDs? It confused me, since coming from the TSX, I know what a projector looks like, and the one on my Z is sort of a half projector. The lights arent that bright, though. Would D2S bulbs do the trick? Do the non-HID headlights look like any other normal headlight, with just a bulb reflecting off of the back of the housing? If someone could clarify this, thatd be great.
Old Dec 3, 2008 | 11:59 AM
t0mills's Avatar
t0mills
If you have a base, you don't have xenon headlamps.
The 350z uses a hyrid projector, or "proflector," as some people say. The projector lens is there to sharpen the cutoff, and helps to soften the light output on the ground.
They use D2R bulbs, which are only used in reflector based lamps.
The output is nothing like a true projector, such as the Stanley made units that were on your TSX.
Many people upgrade to the 06+ headlamps, because they do utilize a true projector, and they have a solenoid which drops the cutoff shield to allow the light to disperse, thus being called a Bi-Xenon projector.
-Tim
Old Dec 3, 2008 | 12:03 PM
Escobar's Avatar
Escobar
^ nice post. I have a base and upgraded to a HID kit. All the models have the same headlight assembly but the base has no starter/ballast or xenon bulb. It is a fairly easy upgrade that looks great and has a lot of functionality.
Old Dec 3, 2008 | 12:13 PM
ohfourzee's Avatar
ohfourzee
ah, just what i was looking for
HID kit is next
any suggestions? was thinking kaixen
Old Dec 3, 2008 | 02:41 PM
redlude97's Avatar
redlude97
This is not true. The nonHID headlight housing uses h7 halogen projectors, which may appear to be the same as the HID version, are not. An h7 bulb and a d2r bulb have different bulb dimensions and are not interchangeable directly. Furthermore, 99% of HID kits used a rebased d2s bulb rather than a d2r bulb with the ceramic shielding, which should NOT under any circumstances be used in an 03-05 housing as it will cause significant amounts of glare for oncoming drivers.
Old Dec 3, 2008 | 02:59 PM
ohfourzee's Avatar
ohfourzee
oh, snap
So, redlude, what do you think I should use, besides the bi-xenons, to upgrade the light output?
Old Dec 3, 2008 | 03:06 PM
redlude97's Avatar
redlude97
If you can't afford the 06+ bixenons then purchase 03-05 OEM HID headlights. At a bare minimum I would use h7 to d2r convertors so you can use OEM d2r bulbs and ballasts with your headlights.
Old Dec 4, 2008 | 08:58 AM
sam2944's Avatar
sam2944
Hello everybody. We at www.sagahid.com have all available. I personally own a Z. If need more info just PM me. Regards.
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
