Luxeon LED pictures...
Old Aug 30, 2003 | 01:46 PM
DIGItonium's Avatar
DIGItonium
Default Luxeon LED pictures...
Hi! I finally got out of laziness and started making LED bulbs featuring Luxeon LEDs. Some of you are familiar with my dome light Luxeon LED mod. I'll post pictures again. It turns out they've improve their manufacturing processes, and the LEDs are much whiter than before. I'll post the dome light for those who never seen it.
So total mods done:
-Dome light (year ago)
-Trunk light
-Parking light
-Front turn signals
Since the signal bulbs use so little current (even at 100mA), the car still thinks a bulb is burnt, so it goes into hyper flash mode. It looks cool for LEDs, but for my rear turn signals it's crap. I'll have the rear Luxeon bulbs made, but I'll do the install later.
Here's the Luxeon Amber Side Emitting LED for my turn signal mod:
Old Aug 30, 2003 | 01:47 PM
DIGItonium's Avatar
DIGItonium
This is the Amber Luxeon lighting up... notice the side emitting radiation.
Old Aug 30, 2003 | 01:48 PM
DIGItonium's Avatar
DIGItonium
These are modded 194 LED bulbs. I took out the original jumbo white LED, and replaced it with this Luxeon. The resistor is mounted externally, and will be hidden behind the headlamp housing.
Old Aug 30, 2003 | 01:49 PM
DIGItonium's Avatar
DIGItonium
This is the 194 Luxeon Mod in action @ 9V:
Old Aug 30, 2003 | 01:50 PM
DIGItonium's Avatar
DIGItonium
This is my front LED turn signal. It uses 4 super bright amber LEDs along with a single amber Luxeon side-emitting LED. I painted it silver to give it a "clear" look.
DIGItonium's Avatar
DIGItonium
This is the signal bulb in action @ 9V.
Old Aug 30, 2003 | 01:51 PM
DIGItonium's Avatar
DIGItonium
Here's a pix of the bulb installed.
Old Aug 30, 2003 | 01:52 PM
DIGItonium's Avatar
DIGItonium
Signal bulb "on."
Old Aug 30, 2003 | 01:53 PM
DIGItonium's Avatar
DIGItonium
Another view...
Old Aug 30, 2003 | 01:54 PM
DIGItonium's Avatar
DIGItonium
At night...
DIGItonium's Avatar
DIGItonium
Here's the original LED 194 bulb... camera exaggerates this stuff.
Old Aug 30, 2003 | 01:56 PM
DIGItonium's Avatar
DIGItonium
Here it is with the Luxeon 194 modded bulb installed...
Old Aug 30, 2003 | 01:57 PM
DIGItonium's Avatar
DIGItonium
The 194 bulb in action at night... who needs hiper white?
Old Aug 30, 2003 | 01:58 PM
DIGItonium's Avatar
DIGItonium
Here's a close-up...
Old Aug 30, 2003 | 01:59 PM
DIGItonium's Avatar
DIGItonium
Here's the combination...
Old Aug 30, 2003 | 02:00 PM
DIGItonium's Avatar
DIGItonium
Here's the trunk light mod...
Old Aug 30, 2003 | 02:01 PM
DIGItonium's Avatar
DIGItonium
Here's the dome light mod I did a year ago when Luxeon was still new. The color rendering of the LEDs weren't as good at the time, but the light is still clean. It doesn't look good on camera though. I'm happy to say these lights are still working.
Old Aug 30, 2003 | 03:12 PM
ares's Avatar
ares
Veteran
looks nice, if you put a resistor equal to the stock bulb in parralel with the LED turn signal bulb, it wont notice its missing.
that should solve your problem
they sell them too, as its a fairly nice sized resistor, they sell it all nicely packaged, bout 5$ a peice. one should do it tho, as they dont go into hyper flash when one is burned out, so I dont see why youd need 2 resistors for both bulbs.
hope that helps.
Old Aug 30, 2003 | 10:26 PM
DIGItonium's Avatar
DIGItonium
Yea... i should do that, but I'm pretty lazy. Also, I don't like splicing wires.
There's more I could've done like add a zener diode, but I'm going to see how long these bulbs will last.
The hyper flash is pretty neat for LED signals, but they're horrible for incandescent lights. I hope to change the rear signals soon.
I'd like to implement an amber and white Luxeon for each clear reflector, but I'm slightly uneasy about splicing any wires.
More LED pictures here:
http://members.***.net/djtonium/html/led.htm
Juztin
Nov 22, 2015 07:03 AM
davidm350
Oct 31, 2015 02:28 PM
Mw870
Oct 2, 2015 08:23 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
imntcrzy
Dec 30, 2002 10:25 AM
