I think this is rust. Two paint chips had orange stuff around it.
Old Feb 14, 2009 | 10:50 AM
KS0385's Avatar
KS0385
Default I think this is rust. Two paint chips had orange stuff around it.
Is this panel not made out of Aluminum? Is it going to rust? Will the dealership fix this with the corrosion warranty, or should I clean it up and cover it up with touch up paint? Has anyone else had this problem?
Old Feb 14, 2009 | 11:14 AM
Jersey Joe's Avatar
Jersey Joe
from my understanding, the corrosion warranty only covers "speed holes". your best bet is to touch it up yourself
Old Feb 14, 2009 | 11:19 AM
CancerJCCz's Avatar
CancerJCCz
Lulz. Just touch it up yourself! Is it even noticeable with the gas door shut? Yes if bare metal is exposed to H2O and Air it will rust.
Old Feb 14, 2009 | 11:21 AM
ecorona6's Avatar
ecorona6
I dont see squat! If its not an 08 or newer dont bother!! Touch it up.
Old Feb 14, 2009 | 11:32 AM
SuperBlack350z's Avatar
SuperBlack350z
yep rust. it's not as easy as just "touching up". that's how future rust happens down the road. you have to get rid of the rust first then touch it up.
Old Feb 14, 2009 | 11:33 AM
KS0385's Avatar
KS0385
It is an 08. And also, if it is aluminum it should not rust. So is this section steel?
Old Feb 14, 2009 | 12:11 PM
For some reason you are banging that edge with the filler nozzle. A little touch-up paint will work.
Old Feb 14, 2009 | 03:22 PM
AstroZombie's Avatar
AstroZombie
Aluminum will corrode but will be white powdery deposits, if the buildup is orange then the metal is steel. if youre really concerned you need to remove it all, meaning you would have to take that section to bare (clean) metal then prime and repaint
Old Feb 15, 2009 | 07:55 AM
KS0385's Avatar
KS0385
I'm thinking about taking off about a centimeter in diameter of paint around each chip, and sanding it then priming and painting. This will be enough to be safe correct?
Old Feb 15, 2009 | 08:04 AM
There are several touch-up threads in the detailing forum. Good reading.
Old Feb 15, 2009 | 12:20 PM
gmic350z's Avatar
gmic350z
cant cut corners when it comes to rust ,no matter how small.get it fixed professionally or in the near future it will cost you alot more to fix it.pretty much brand new car,i wouldnt mess around.get it done
Old Feb 15, 2009 | 02:27 PM
350z-Jim's Avatar
350z-Jim
That panel is not aluminum. Use touch up paint and it will be fine. That is only surface rust like what happens to your rotors when it rains and the car sits.
Rev_Night
Nov 7, 2020 06:00 PM
Cashwin
Oct 1, 2015 06:36 AM
