Tried my hand at painting!
Old Feb 16, 2009 | 04:42 PM
Subninja's Avatar
Subninja
Default Tried my hand at painting!
Well I decided to paint some stuff on the car. I used spray paint and was pleasantly surprised with the outcome. Here are the pics.
The other one is painted as well.
Overall it turned out great and I am very satisfied with the results.
Old Feb 16, 2009 | 04:49 PM
jerry_2612's Avatar
jerry_2612
If it's just basic spray paint I'm pretty sure it's going to peel straight off with heat and wear and tear...
Old Feb 16, 2009 | 04:52 PM
Spork's Avatar
Spork
hopefully you sanded, primed, colored, and cleared.
Old Feb 16, 2009 | 04:53 PM
Mike Wazowski's Avatar
Mike Wazowski
you might want to strip them and use and adhesion promoter prior to painting them. Also I would recommend high temp paint.
results look nice though.
Old Feb 16, 2009 | 05:13 PM
freedonutss's Avatar
freedonutss
I did this to my stockers and they are lasting. 7 coats of black and 5 coats of clear coat. Light coats but many coats is the key.
Old Feb 16, 2009 | 05:15 PM
Subninja's Avatar
Subninja
Well it was paint for plastics but I don't know how it will hold up against the heat of the engine. Only time will tell. I am not to worried about the battery and brake cover. I will post pictures up later to let you all know how it is fairing.
Here was my process. I first cleaned with dishwashing liquid and then dried it. I then used a blue plastic base coat which was a little lighter than daytona blue. I sprayed 2-3 coats of that. Then I sprayed 2-3 coats of blue metallic fleck. This really comes close to daytona blue and even has that "sparkle" that is in the OEM paint. And finally I sprayed 2-3 clear coats on. Hopefully it will last for a while. Either way it was fun and I am proud of the result.
Old Feb 16, 2009 | 05:46 PM
You did good. I am sure that our best painters started someplace.
Old Feb 17, 2009 | 10:51 PM
EricChan's Avatar
EricChan
Banned for NON PAYMENT
The Fluid and Battery covers should be fine since they don't see too much heat. I have seen people who have had the paint spider/ peel because of the paint they used. overall looks nice! now you gotta get off the cans and try your hand at a gun... Im still trying to get good at it.
Old Feb 17, 2009 | 11:01 PM
SuperBlack350z's Avatar
SuperBlack350z
those blue has too much orange peel effect. I guess it's not bad for a rattle can but if you do some sanding and polishing, rattle cans can look really good.
Old Feb 18, 2009 | 11:39 AM
arneltec's Avatar
arneltec
Using a spray gun is way different. I would suggest finding a well ventilated and covered area like a large shed or detached garage. If you use it in an attached garage I would seal off the door to the house or the fumes will get in. Breathing mask is a must.
Old Feb 21, 2009 | 01:23 PM
Subninja's Avatar
Subninja
Yeah...I live in an apartment so I don't exactly have any room. I did most of this indoor and outdoors so it won't be perfect. I wish there was a school you could go to for this.
Old Feb 21, 2009 | 02:07 PM
SuperBlack350z
my body shop guy can make a rattle can job look really nice.
even if you used a professional spray gun in a ventilated area, it will still come out to be the same just with less trash in the clear. It would still come out with orange peel. Orange peel is mostly from the clear coat. once you sand and buff, it will come out looking great.
Old Feb 22, 2009 | 09:08 PM
Subninja's Avatar
Subninja
Yeah the engine cover does have orange peel. How do I sand it away...just really fine grit sand paper....and will I have to recoat it?
Old Feb 22, 2009 | 09:27 PM
SuperBlack350z
for this, i would get a 2500 grit sand paper sheets, wet it really good and start spraying the engine cover with water. Start sanding it everywhere evenly.
This will make the engine cover very dull looking. you have to bring back the shine. use a heavy cut compound followed by a light polish and you are good to go. Should look very slick and nice.
Old Feb 24, 2009 | 06:21 PM
zman600's Avatar
zman600
i did it the right way and got great results...
took me a while to do cus i used alot of coats
high heat paint FTW
Attached Thumbnails Tried my hand at painting!-1216080204a.jpg   Tried my hand at painting!-downsized_1216081041.jpg
Old Feb 24, 2009 | 06:34 PM
galant350z's Avatar
galant350z
^ looks good bro!
Old Feb 24, 2009 | 06:35 PM
zman600's Avatar
zman600
^thanks alot ill try and get a pic of it on the car
Old Feb 24, 2009 | 06:58 PM
zman600's Avatar
zman600
got um...
people love this at car shows
*note if anyone want that hood in the back ground in selling it.
Attached Thumbnails Tried my hand at painting!-0224092146a.jpg   Tried my hand at painting!-0224092147.jpg   Tried my hand at painting!-0224092146.jpg   Tried my hand at painting!-0219092321a.jpg
Old Feb 26, 2009 | 01:42 PM
brigz's Avatar
brigz
man that hr engine cover looks so much better than the de's
Jambo016
Sep 16, 2016 01:08 PM
Cashwin
Oct 1, 2015 06:36 AM
