Center Console Blacked Out
Old Mar 14, 2009 | 03:29 PM
lbz's Avatar
lbz
Default Center Console Blacked Out
Not a big fan of the silver trim located throughout the interior so I'm blacking out as much of it as I can. Also wanted to clean up the console, get rid of the scratches.
Posted the lower half of the center console last week. Here's the results of doing the upper half today.
The cubby door BEFORE - notice my lame attempt at fix with Sharpy
The cubby door AFTER - I need to get a better pic I know The little bumps on the door release button are sanded off.
Lower Half from last weekend
Gauge cluster detail
The entire console
Color comparison between the newly painted upper console and the passenger side of the dashboard
Comparison lower down to the left of where passenger's legs go - out of focus but you can see the color is pretty close match
Another shot of the entire console but more straight on relative to the gauges.
The paint is a bit more reflective than stock but not a whole lot more. Also, I'd like to figure out now to make it smoother to the touch. As it is spray paint, it's not as smooth to the touch as factory... I figure to let it go for a week or so and then maybe rub it down with soft cloth or something... I'm open to suggestions. Overall, I'm happy with the results and will post a procedure later today.
Doing the doors next week.
Old Mar 14, 2009 | 03:48 PM
stein's Avatar
stein
I like it! How did you prep it prior to painting and what paint did you use?
Old Mar 14, 2009 | 04:15 PM
10-E-C-350Z's Avatar
10-E-C-350Z
+1, what kind of paint did you use? I would have worn different shoes for the photo shoot though.
Old Mar 14, 2009 | 05:15 PM
carbonwarriorZ's Avatar
carbonwarriorZ
Looks good. Are you planning to paint the rest of the interior to match?
Old Mar 14, 2009 | 05:18 PM
SoldzMyZ's Avatar
SoldzMyZ
WOW details please. Very taste full!
Old Mar 14, 2009 | 05:20 PM
drewk's Avatar
drewk
Well done... what paint did you use?
Old Mar 14, 2009 | 05:21 PM
AdriaN-'s Avatar
AdriaN-
Dude it came out very very clean. Congrats and nice work. Share the secret to us fellow Z'ers!!
Old Mar 14, 2009 | 05:32 PM
lbz's Avatar
lbz
No prep other than to wash with a wet soapy cloth and dry.
Because I wanted to retain the texture, I wasn't going to sand or do anything abrasive. Time will tell if it starts to flake but so far the bottom half, at one week, is good to go with no cracks. If it starts to flake, crack or otherwise get messy, I will post a follow up.
Paint used: DupliColor Fabric and Vinyl - Flat Black. I got it at Pep Boys for around $7 / can. Took two cans to do both the top and bottom. I probablyl used more than needed but wanted to make sure I hit all the angles.
I do intend to do the rest of the interior. Found a procedure for removing the main gauge cluster over the steering wheel, have that off now and just finished painting the silver plate that sits on the front. Should be able to re-assemble and remount it before dark.
Looking to pull those two silver pieces off the steering wheel but not sure what the relatinonship is to the airbag. I assume they are just trim and after removing the single screw in the back, should pop off with a tape covered flat blade. Anybody know anything about those? Just trim is all? Last thing I want is a heart attack and $$ to replace the airbag as a result of a project like this.
Next week I will be doing the doors, all the silver trim except the door locks, will leave those as is.. I hate that silver strip in the passenger side door grip. Also, the drivers' side door control panel is scuffed up so I will pull that, sand it some to get rid of the scratches and paint it.
I already have black replacements for the door sill guards so that's already done.
The rear strut brace cover will be the last thing. Anybody know what year they switched from the silver cover to a darker one and whether or not it will fit an 05?
Old Mar 14, 2009 | 05:38 PM
06z33's Avatar
06z33
This looks 10x better than stock. Great job!
Old Mar 14, 2009 | 05:50 PM
jtabraham's Avatar
jtabraham
Looks great! It definitely softens the "plasticy" of the stock console.
lbz's Avatar
lbz
Thanks for all the compliments. I'll have pics and the procedure posted up tomorrow.
Old Mar 14, 2009 | 06:20 PM
Zenica's Avatar
Zenica
Can you post the resource you found for removing the gauge cluster?
I want to try changing the bezel in mine and cleaning the dust inside but have yet to find anything that offers a clue on the cluster removal.
Old Mar 14, 2009 | 06:25 PM
SuperBlack350z's Avatar
SuperBlack350z
i've used duplicolor on a lot of friend's car. Flat black is the one to get. the gloss one is really glossy and looks bad. But i would advise others to get duplicolor adhesion promotor. It helps a lot with plastic.
Old Mar 14, 2009 | 06:50 PM
Ruthless18x's Avatar
Ruthless18x
Looks pretty good actually. It's just amazing how many scratches people have on their interiors.
Old Mar 14, 2009 | 07:18 PM
quakerroatmeal's Avatar
quakerroatmeal
You even painted the shift ****. I like the silver trimming, gives it a contrast look.
Old Mar 14, 2009 | 07:20 PM
lbz's Avatar
lbz
I'll be including the gauge removal in my procedure but here's the link I found:
https://my350z.com/forum/exterior-an...e-cluster.html
Old Mar 14, 2009 | 07:22 PM
Nexx's Avatar
Nexx
+1, i dont wear rings is maybe why my interior doesnt get these weird scratches.
lbz's Avatar
lbz
Just the top shift pattern plate and bottom metal piece. I'm going to replace it with the nismo black one next week.
I just finished the steering wheel gauge cluster and got it remounted. Dark out so no pics but first thing in the morning I'll have a pic up and then later the procedure.
Old Mar 15, 2009 | 01:12 AM
Thumbs up
Very clean. Exceptional match.
Old Mar 15, 2009 | 05:27 AM
pony_killer's Avatar
pony_killer
Arada ninda apa
i don't either but do you think it might have anything to do with fingernails? (pk has trimmed and neat fingernails )
op good job
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
