Need help with cf front lip
Old Mar 17, 2009 | 10:18 PM
ma6icman's Avatar
ma6icman
Default Need help with cf front lip
I recently purchased a seibon cf cw style front lip. However I'm having trouble putting it on because it's not clearing the mouth of the bumper. Does anyone have any ideas, info or a diy on how to install this lip???
Old Mar 17, 2009 | 10:25 PM
aloh's Avatar
aloh
post some pics of what you mean. Im having a hard time picturing it in my head. When I installed mine, you have to slightly bend the bumper a bit to get the lip's corners to get onto the bumper. Do it carefully or else you might crack the CF.
Old Mar 17, 2009 | 11:11 PM
ma6icman's Avatar
ma6icman
I'll take pics tomorrow. Is there a diy on how to install this type of lip in cf cause I don't want to force it and then makebit crack
Old Mar 17, 2009 | 11:12 PM
ma6icman's Avatar
ma6icman
which part of the bumper did u have to bend? And is it best to do it with the bumper off the car?
Old Mar 18, 2009 | 10:09 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Isn't the "mouth" where the 03-05 and 06-08 differ? Are you sure it's for the right year?
Old Mar 18, 2009 | 01:39 PM
ma6icman's Avatar
ma6icman
yeah the lip says 06, should
I try sliding it on from the bottom
Old Mar 18, 2009 | 01:53 PM
Mr. CF's Avatar
Mr. CF
I have the same thing,has to come up from the bottom like ^ was saying then swing the center piece over the center bumper section
Old Mar 18, 2009 | 04:04 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
+1. I had the same problem with a Veilside v1 lip. I fought and fought. Flexed the bumper. Did everything I could think of. Last thing I tried was sliding up from the bottom and it slid on simply. Did have a little scratching of the bumper though.
Old Mar 18, 2009 | 06:40 PM
aloh's Avatar
aloh
Definately take the bumper off of the car.
Heres a the idea of what i did. Lets say the ubmper looks like this ( before you flex it. I had to bend it to something like this: < Though obviously it doesnt get sharp or pointy...otherwise you just broke your bumper. By bending it like that, I was able to get the edges of the bumper on and everything else just fell into place. Beware of scraping your paint on the edges of the lip though. You should also be aware that the grille in the middle is resistant to flex cause it is made out of a harder plastic...you dont want to crack that either.
It will be MUCH easier to do this with help from a friend.
Old Mar 19, 2009 | 09:24 AM
VeilSideBrian's Avatar
VeilSideBrian
With the front lips, VeilSide or otherwise, PLEASE install the center part first.
It will NOT WORK if you try to do one side at a time.
Old Mar 19, 2009 | 09:13 PM
ma6icman's Avatar
ma6icman
thanks for the info, im going to try it this weekend
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
