350z interior lights help!!!!
Old Mar 27, 2009 | 03:15 PM
Jasons350z's Avatar
Jasons350z
Default 350z interior lights help!!!!
Whats up guys I need a little help..about a month ago my dome lights stoped workin on my 03 Z,when I open the door the light doesnt go on,or when i try to turn the lights on they dont work...I check the bulbs there good,checked all the fuses and yes I check the fuse for (room lamp-trunk lamp) there all good.I took off the driver side pilar...and checked the harness for the dome light..got no power..tested wit a test light...my trunk lamp works though...I was wondering if there was a relay or something else that went bad...thanks guys Jason
Old Mar 27, 2009 | 03:31 PM
WhiskeyHotel's Avatar
WhiskeyHotel
You know - I hate to mention this, but there is a switch on the thing that will turn it off.
Good luck -
Old Mar 27, 2009 | 05:42 PM
Jasons350z's Avatar
Jasons350z
Good luck -
lol I know theres a switch to turn it off...if you dont want the lights to come on when u open the door...but i have no lights at all
Old Mar 28, 2009 | 07:52 AM
sam2944's Avatar
sam2944
What he means is the switch in the inner fender of the door beside your seat.
Old Mar 29, 2009 | 04:31 PM
Jasons350z's Avatar
Jasons350z
behind the panel
Old Mar 30, 2009 | 08:39 AM
WhiskeyHotel
Ah. Well, as you can see, I'm not gonna' be any help. Can you borrow a voltmeter? That's the only way I know to trace the circuits, checking for voltage along the way.
Old Mar 30, 2009 | 01:14 PM
kevincat's Avatar
kevincat
try this.
unplug the negative part of the battery and leave it out for 30 seconds.
while its out step on the brakes a few times.
maybe that will solve it.
Old Mar 30, 2009 | 03:26 PM
Jasons350z's Avatar
Jasons350z
Originally Posted by kevincat
try this.
your the man bro..it worked thanks bro
Old Mar 30, 2009 | 04:45 PM
kevincat's Avatar
kevincat
Old Mar 30, 2009 | 06:51 PM
WhiskeyHotel
Ah, an ECU reset to fix the lights - who woulda' thunk it.
Miguel Albanez
Oct 17, 2022 10:13 AM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
hardkicks
Sep 20, 2015 12:28 PM
