are those manufacturer defects? or i was fooled?
Old Apr 19, 2009 | 09:47 AM
maXmood's Avatar
maXmood
Under Boost!
Default are those manufacturer defects? or i was fooled?
i got the car in late 2007 (tho it's 2006 model with 6k odo), and a clean title. i got it shipped from US to Bahrain, which took about a month (the whole process took me 4+ months).
after receiving it for a while, i've noticed a gap between the front bumper and the headlight, i thought maybe it was a manufacturer's defect, and never gave it attention.. and last night, i've noticed some worn rubber (dunno what they're called) at each end on the front glass window, also i noticed the passenger side/side skirt isn't fit as well..
so i'm thinking, is it a manufacturer's defect? or did that happen with the previous owner but he never reported it? or is it because of the shipping?
i don't know if those are fixable, but i'm sure a new replacement part should fix it, tho i don't want to spend cash on fixing those issues, but rather spend it on aftermarketparts.
on with the pix:
Headlight fitment issue
and the worn rubber
Side skirt fitment issue
comments/suggestions are welcome.
thnx
Old Apr 19, 2009 | 10:11 AM
xpock182's Avatar
xpock182
The "rubber" seal isnt an issue i dont believe. Ive had two 350'z and both had the same deal. I think after awile outside they just tend to get a little Corroded. As for the bumper. Just get an aftermarket one IMO. & my Z defently didnt come with side skirtz. lol. Little Gimpy mud flaps maybe. But not full side skirts.
Old Apr 19, 2009 | 10:59 AM
maXmood's Avatar
maXmood
Under Boost!
ok, good to hear about the rubber thingy..
but, there must be OEM side skirts, without it, u'd see the chassis (i guess)??.. i took few pix, tho it's night time here.. i'll upload them and update OP.
Old Apr 19, 2009 | 11:54 AM
maXmood's Avatar
maXmood
Under Boost!
OP updated...
thnx
Old Apr 19, 2009 | 04:04 PM
gr8scott_o's Avatar
gr8scott_o
My '06 is very similar in all regards. The rubber part on my windshields are not nearly as worn, however I can see that mine are deteriorating.
Old Apr 19, 2009 | 04:18 PM
maXmood's Avatar
maXmood
Under Boost!
so u got the same fitment issues???
Old Apr 19, 2009 | 04:46 PM
gr8scott_o's Avatar
gr8scott_o
Yes. I didn't really notice until I was looking at some shots I took today of the headlights, but since I just put the bumper back on I have no one to blame but myself. Lining everything up should be really easy, since I have now taken the bumper cover off several times I have a pretty good handle on what bolts to loosen to align the cover. The fenderwell splash guards pop off pretty easily, one phillips head screw and three pop-up plastic rivets hold that piece on. Then, once removed, one 10mm bolt and three 10mm hex head screws to loosen and adjust. Taking the tire off gives one more room to work.
But on the side skirts, every time I get in my car the darn things look like they were never fit correctly from the factory. Definitely more noticable when the door is open.
Old Apr 19, 2009 | 04:57 PM
maXmood's Avatar
maXmood
Under Boost!
thnx dude.. it sux, but at least i know i'm not alone.
i'll try to get the bumper off and try to adjust/fix those issues.
thnx again.
Old Apr 20, 2009 | 02:21 AM
maXmood's Avatar
maXmood
Under Boost!
i checked a DIY "Front Bumper Removal", but i haven't seen anything where i can tighten and adjust the thing.
anyways, i'll give it a shot coming Sat.
Old Apr 24, 2009 | 03:53 PM
Xzero's Avatar
Xzero
I just did the 03-05 HID to 06+ Bi-Xenon swap and I have the exact same gap on the headlights. It seems to be that way with everyones. I'll post pics of mine when I get home.
As for the rubber trim, I have no problems that I know of but I'll post pics of that too.
Old Apr 24, 2009 | 04:12 PM
maXmood's Avatar
maXmood
Under Boost!
so there isn't anyway to adjust/fix it??
Old Apr 24, 2009 | 05:10 PM
Xzero's Avatar
Xzero
I tried everything and they just seem to stay that way. I did not see any adjusting screws or anything like that. I cant remember what the 03-05 headlights look like on a car.
Anyone wanna take a few pics of thier 03-05 headlights? I want to see the difference in the gaps.
Old Apr 24, 2009 | 08:51 PM
angelzhope720's Avatar
angelzhope720
I got into a minor accident with my first Z and ever since then there was a gap just like yours and it drove it absolutely insane. Hopefully your Z wasn't in an accident.
Old Apr 24, 2009 | 08:53 PM
Xzero's Avatar
Xzero
Please excuse my dusty car. She's been sitting for a few months waiting for winter to be gone. So I have a few pics here. I think you need to get your weather stripping and the side skirts checked out. I still think the lights having a gap are normal.
Here is a shot of the passenger light:
Here is a close-up of the gap in the headlight:
Here is the weather stripping on the drivers side, passenger is the same. It seems you're missing a whole chunk off of it!:
Here's near the door sill. No gap at all....:
Old Apr 24, 2009 | 09:41 PM
b_nazty's Avatar
b_nazty
maybe the the car had a kit before and te stock parts were put back on before it was sold...thats kinda what my side skirts looked like when i out them back on
Old Apr 25, 2009 | 05:37 AM
crypticsage's Avatar
crypticsage
i have an 04 black z and have the same exact rubber by the door issue and headlight issue.
Old Apr 25, 2009 | 01:26 PM
maXmood's Avatar
maXmood
Under Boost!
alright..
I'M NOT ALONE!
thnx for ur input guys. i think i'll just live with it. and bout the rubber thingy, it's cuz of our weather/direct sun on the car. replaceable i guess.
Old Apr 26, 2009 | 06:44 AM
sry110's Avatar
sry110
There is a little adhesive pad (like 3M double-sided tape) around that area of the OEM side skirt that should keep it from popping out like that. See link below, second set of images down, part no. 76898R. If the previous owner ever took off the side skirt and did not replace this adhesive before reinstalling, then I could see why it might stick out there.
http://www.courtesyparts.com/350z-pa...5_846_849.html
Old Apr 26, 2009 | 09:44 AM
Xzero's Avatar
Xzero
Do you have the 03-05 lights in? Can you take a couple of pics for comparison?
Old Apr 26, 2009 | 10:06 AM
maXmood's Avatar
maXmood
Under Boost!
probably is... u think putting 3M adhesive tape would do the job? cuz the part u're referring to costs around 20 bucks.!
