Steering Wheel?
Old Apr 19, 2009 | 11:45 AM
User 42426's Avatar
User 42426
Default Steering Wheel?
So I was looking around and found a momo steering wheel that I like. Would all I have to do is take the stock steering wheel off and just put the aftermarket wheel on? Would I need to buy hub adapters, a quick release or quick tilt systems? What exactly do those do?
And can I use the stock air bag and put it in the new wheel? or is that not even possible, plz help since I do not know much about steering wheels, thanks.
Spork's Avatar
Spork
You'll lose your air bag.
Old Apr 19, 2009 | 12:39 PM
User 42426's Avatar
User 42426
hmm well that sucks
Old Apr 20, 2009 | 06:22 PM
allturbo's Avatar
allturbo
you can find an aftermarket steering wheel that will accept your air bag, and Yes you will need a hub adapter
Old Apr 20, 2009 | 06:43 PM
Voboy's Avatar
Voboy
some momo steering wheels do hold the air bag..
Old Apr 20, 2009 | 07:14 PM
Ruthless18x's Avatar
Ruthless18x
As said above, most aftermarket steering wheels will cause you to lose the air bag. There is a Nismo wheel that houses an airbag though. You'll also need a hub adapter, and you'll probably want a quick release as well. Also an aftermarket wheel will be closer to you than the stock wheel is, so you need to decide if you're going to be okay with that.
Old Apr 20, 2009 | 08:31 PM
User 42426's Avatar
User 42426
I c. Why would I need the quick release for? Wouldnt that make it easier to steal?
Old Apr 20, 2009 | 11:01 PM
ekidd's Avatar
ekidd
well thats what the quick release would be for. To take the wheel off the car when parked or something. If your going to leave the car without a wheel, might as well get a quick release lock too.
Old Apr 21, 2009 | 06:36 AM
Ruthless18x
If you wanted to pop the steering wheel out when you park it, or leave the car somewhere. Also makes accessing the dash a hell of a lot easier. Having a quick release would make the car harder to steal, as long as you take the wheel out.
Old Apr 21, 2009 | 09:16 AM
User 42426's Avatar
User 42426
What if I didn't want the hassle of carrying my wheels around all the time after I park? Would it be better to just not buy a quick release? Or is that where the quick release lock comes into play?
Old Apr 21, 2009 | 09:18 AM
User 42426's Avatar
User 42426
I want it to be like the stock steering wheel. I want to be able to park, go out for a couple of hours, or even at night where i park outside, and just leave the steering wheel in the car knowing it won't get stolen.
Old Apr 21, 2009 | 12:52 PM
Chebosto's Avatar
Chebosto
i think you guys are missing the point.. quick release is /was meant to allow the driver to get in/out of a racing bucket with high side bolsters for driver changes during racing... the anti-theft was a 2ndary benefit.
if you are going to change to an aftermarket steering wheel. you must pick an adaptable hub for the steeringwheel you're going to choose. you do not need a quick release if you do not want to. that will determine your hub length. and how far you want your steering wheel to sit while driving.
stock airbag will not work with your aftermarket steering wheel. there are a few options that have an airbag built in- i believe there was a nismo version by Momo that incorporated this...
there is actually quite a few threads about this.. when searching use quotation marks to better isolate your results..
Old Apr 21, 2009 | 04:03 PM
User 42426's Avatar
User 42426
So if I don't wish to remove my steering wheel for whatever reason, I would be fine with just the hub adapter correct?
And you said something about the hub length and how far I want the steering wheel to sit? Is that determined by the hub adapter?
Old Apr 21, 2009 | 06:01 PM
Chebosto's Avatar
Chebosto
yes. then all you need is a hub with the right bolt pattern/pitch for whatever aftermarket steering wheel you choose. (momo, sparco, nardi,personal, etc)
yes. pretty much. along with the 'depth' of the steering wheel. for example deep corn style (which pushes the steering wheel out)
vs flat
will all effect which length hub you should get.
Old Apr 22, 2009 | 12:04 AM
User 42426's Avatar
User 42426
Thanks guys for helping me out, especially chebosto for clarifying everything :]
Obadabot
Jun 18, 2023 11:31 PM
