Need your help to install the clear front reflector lenses
Old Sep 18, 2003 | 07:12 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Question Need your help to install the clear front reflector lenses
Hey guys, I am going to Courtesy Nissan parts department to pick up my clear side marker tom. and I have some question need you guys help me answer, b/c I will be install myself over the weekend, and before I do it I need to make sure what I am doing, so....
First, is it hard? does it need professional to install for me?
Second, does it require to take the bumper off to install this? if yes, how to take the bumper off?
Third, what do I need to be aware off, so I wont mess up the car when I install this?
Thanks
Old Sep 18, 2003 | 07:24 PM
MY350Z.COM's Avatar
https://my350z.com/forum/showthread....540#post326540
https://my350z.com/forum/showthread....threadid=33575
Old Sep 18, 2003 | 07:41 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Default Thanks Mike
Thanks for replied me and the info you provided
Old Sep 18, 2003 | 07:54 PM
ares's Avatar
ares
Veteran
its not so much hard as time consuming... and somewhat imtimidating. once you get down to it, do it one thing at a time with the proper tools and youll have no problems.
Old Sep 18, 2003 | 08:22 PM
seanrulz's Avatar
seanrulz
Ares, are you still working on new LED sidemarkers and Z4 style LED blinkers? I'm anxiously waiting...
Sorry for hijacking the thread tho
Old Sep 18, 2003 | 08:41 PM
ares's Avatar
ares
Veteran
yes and yes, but itll be a bit longer, but not abandoned by a long shot.
Old Sep 19, 2003 | 07:11 AM
t32gzz's Avatar
t32gzz
I actually paid to have this done because I did not want to remove the bumper......big mistake!!! This is so east to do, as I found out later!
1. Turn your wheel all the way to the left, remove the screws on the driver side fender well.
2. Pull the plastic away from the fender.
3. The side marker is now right in front of you. Remove two screws, pull out the old one, insert the new one, replace the screws.
4. Put the fender plastic lining back in, replace the screws, and repeat steps for the passenger side, but turn your wheel to the right.
1 to 2 hours tops! Good luck!
Old Sep 19, 2003 | 01:02 PM
cybercath's Avatar
cybercath
It's not a hard project (especially if you have small arms and hands to get in there). It took me about 30 minutes to install both sides. The passenger side is a bit more difficult to get to with the windshield washer container in the way.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
davidm350
Oct 31, 2015 02:28 PM
Mw870
Oct 2, 2015 08:23 AM
3oh5z
Exterior
Sep 22, 2015 10:09 AM
