:( gas tank cover keeps getting stuck
Old Jun 6, 2009 | 05:03 PM
maXmood's Avatar
maXmood
Under Boost!
Unhappy gas tank cover keeps getting stuck
i've noticed that for the last couple of months.. i press the button, but it won't open immediately, i have to either press it couple of times, or press and hold, release after couple of seconds.
i checked it the other day, and found out that the pin (or w/e it's called) won't release (move back), when the button is pressed. of course, it doesn't happen always, but most of the times.
what's up with that? can i fix that myself? if not, will the stealership ask for an arm and leg?
thnx
Old Jun 6, 2009 | 06:25 PM
graffkid732's Avatar
graffkid732
That happened to me also. But now it works fine again. I have no idea, I didn't do anything differently. But my new thing is, the button you push, falls out of place at times, so be careful pushing it in.
Old Jun 6, 2009 | 07:14 PM
mw9's Avatar
mw9
same thing happen to me, there was a thread somewhere on it. I adjusted mine by putting washers under one of the bolts of the cover. It got my cover flush with the fender and opens everytime now.
just found this TSB.
File Type: pdf
Old Jun 6, 2009 | 10:33 PM
Waiz's Avatar
Waiz
Dude, thanks for posting this.
One of the last remaining gremlins with my car after the fuelfiller cap/clicking rear axle/ cold brakes squeak issues were addressed.
Old Jun 7, 2009 | 03:01 AM
maXmood's Avatar
maXmood
Under Boost!
thnx for the input and the TSB.. but, i don't think that's my issue here.
it's the actuator that's not operating properly. and my car is '06 model.
Old Jun 7, 2009 | 03:39 AM
maXmood's Avatar
maXmood
Under Boost!
i searched the forum couple of times now, and i can't even find a similar case.
Old Sep 11, 2009 | 10:52 AM
yogipower's Avatar
yogipower
did you ever take your z to stealership?
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
