Clear Corner Installation?
Old Sep 26, 2003 | 03:26 PM
Kenyon's Avatar
Kenyon
Default Clear Corner Installation?
hey guys, do I need to remove the bumper to install the lights?
Old Sep 26, 2003 | 04:07 PM
ares's Avatar
ares
Veteran
are you talking about the reflectors? if so, then yes/no, for the drivers side no. but the passenger side has a windsheild washer resevior in the way, so if you have small hands or the right tools, you may be able to do it with the bumper on. I personally had to take it half way off and just pull it out a little to get some space to work.
your primary entry is through the wheel wells tho, you have to remove them either way to get to the bumper mounts.
Old Sep 26, 2003 | 04:25 PM
uptuit's Avatar
uptuit
I was in for a scheduled service @ AutoWay Nissan in Largo' Fl. asked the service writer to have my clearside reflectors installed...he said no problem. Great dealer... no charge, ask for Rob in sales if you want this kind of service. BTW.....this is unsolicited...I'm a business owner and when a car dealer treats a client in this fashion they deserve a shout-out.
Uptuit
Old Sep 26, 2003 | 05:12 PM
Kenyon's Avatar
Kenyon
would i need to take out my tires to get to the wheel wells or just turn the tires?
Old Sep 26, 2003 | 05:32 PM
ares's Avatar
ares
Veteran
turning the tires id sufficient, if you have a set of car jacks that too helps since itll let out the suspension, increasing your room to work.
no need to remove the tires tho.
Old Sep 26, 2003 | 05:36 PM
Kenyon's Avatar
Kenyon
thanks for the help, I'll get on it tomorrow. any advice on removing the 350z emblem? will floss do?
Old Sep 26, 2003 | 09:33 PM
ares's Avatar
ares
Veteran
that I havent tried, but have heard good things about a nice weight fishing line, I think I remember someone saying floss kept breaking, but you could give it a try.
my personal guess would be to let it sit out in the sun before hand, might help get the tape nice and gooey.
Old Sep 26, 2003 | 09:59 PM
DruDragzOn's Avatar
DruDragzOn
Blowdry it and use floss. Shouldn't be that bad. The only annoying part is taking off the rest of the glue stuck on the car after you take off the emblem.
