scratches/chips on driver's armrest
Old Jul 19, 2009 | 01:19 PM
bailey bill's Avatar
bailey bill
Default scratches/chips on driver's armrest
The plastic panel on the driver's side door, the part that you grab to open or close the door, is badly scratched, mostly from my wedding ring. It really looks crappy.
How would you refinish or replace that peice?
bill
Old Jul 19, 2009 | 01:38 PM
DavesZ#3's Avatar
DavesZ#3
You talking about the problem shown in this thread...
https://my350z.com/forum/exterior-an...ng-to-you.html
Replacment is easy but not cheap. Not sure if you can refinish it. It's basically a rubberized coating that would be difficult to match.
Old Jul 19, 2009 | 02:16 PM
BLK350GT's Avatar
BLK350GT
Some body on this site did a DIY fix on this issue. Search this sire. He took it off, sanded it down and repainted it. I have the same problem. I actually used a Sharpi that was the same color. Sounds lam I know but it worked.
Old Jul 19, 2009 | 02:22 PM
DavesZ#3's Avatar
DavesZ#3
You're probably thinking of this thread...
https://my350z.com/forum/exterior-an...scratches.html
Look on the last page.
Old Jul 19, 2009 | 03:02 PM
BlueZ33's Avatar
BlueZ33
is this covered under the bumper to bumper warranty from nissan
Old Jul 19, 2009 | 08:02 PM
Waiz's Avatar
Waiz
If its that bad, just replace it.
Its less than $30 and only takes a flat head and a phillips to replace.
Old Jul 19, 2009 | 10:09 PM
spinviper's Avatar
spinviper
How ?
Old Jul 20, 2009 | 12:02 AM
lbz's Avatar
lbz
Get a can of DupliColor for Vinyl and Fabric, Flat Black. Some sanding and then shoot it with the duplicolor. Done.
There is a cap in the depression, pop the cap, remove the screw and you can pop off the handle.
Disconnect the two wiring connectors.
You can unclip the control boxes using a flat blade to pry the clips back.
Old Jul 20, 2009 | 06:05 AM
bailey bill
I'm not sure what "depression" refers to? I have looked all over the whole area and do not see anything i would call a "cap".
Your help is appreciated.
bill
Old Jul 20, 2009 | 06:22 AM
JasonZ-YA's Avatar
JasonZ-YA
^ guessing by your join date, your car handle doesnt have the pocket for coins......just a handle..........so the cap IBZ is talking about isnt there........its only in the 03-05 models where there is a cap with a screw under it to remove that part located in the coin holder section......
What year is your car.......if a 06 and up model, then i believe you need just a flat head screwdriver and pry at the sides carefully and it all pops out.......
-J
Old Jul 20, 2009 | 07:29 AM
bailey bill
-J
Yes, mine is an '06, and no, it does not have a "coin pocket".
By "at the sides" do you mean the area toward teh front and the rear. or the area along the side that runs front to back.
(It looks bad enough as is, I really don't want to make it worse by damaging trying to remove it.)
Thanks
bill
Old Jul 20, 2009 | 09:54 AM
spinviper's Avatar
spinviper
Hey I found this
http://www.nicoclub.com/articles.php?id=353928
but it 03-05, mine is 06. I wish anyone could do that for 06 door handle.
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
