A/C not working...some help please
Old Aug 11, 2009 | 12:16 PM
tonester1011's Avatar
tonester1011
CF God
Default A/C not working...some help please
so heres whats going on....
i turn the a/c on and it does not come out cold....only blows out warm air...it did that for a few days and now when i turn the a/c off it blows full blast warm air...the **** still works so that it comes out harder and harder as u turn it up but its warm, and like i said once i turn it off it blows out full blast....all fuses are ok and everything i can think of looks good...its drivin me crazy so if anyone has had this problem please tell me where to look...i was thinkin maybe the ***** are bad or maybe the a/c amplifier piece behind those ***** are no good...any help is appreciated.
Old Aug 11, 2009 | 12:25 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
your freon leaked out? common with tt setups
need to bring it to a shop for them to put the dye in the system, see where the leak is, replace the faulty hose, and recharge the system
Old Aug 11, 2009 | 01:55 PM
Chomorro's Avatar
Chomorro
I have the same problem man, My Thread But mine blows out cold air just wont turn off when i turn the switch off. No luck on finding a fix yet, im hoping it will just go away since my other switch problem seems to have LOL. It has to be common on Z's because i can find a few threads with people having the same problem but no fixes.......
Old Aug 12, 2009 | 06:57 AM
tonester1011
CF God
you think?? i can see the lack of freon making it not blow out cold but would that have anything to do with the blower not turning off when it is in the off position??
Old Aug 12, 2009 | 06:58 AM
tonester1011
CF God
same problem but my car hasnt been in the shop for anything for well over a year....this just happened out of nowhere....2 weeks ago a/c was fine and then one day it went wacky.
Old Aug 12, 2009 | 07:38 AM
zerafian's Avatar
zerafian
I'll let you know later on. I have the same problem. The AC likes to turn itself to max as well as switch itself to outside air once in a while. ITs covered under my warranty still so Im gonna get that checked out.
Along with my driver side window not wanting to go down sometimes. I have to reshut the door sometimes.
Old Aug 12, 2009 | 08:47 AM
Chomorro's Avatar
Chomorro
I may have a solution, i had to drive to work today with the a/c on full blast..... Anyways i pulled the climate control console off when i was in the parking lot and push the white ribbon behind it in slightly and a/c shut off!!!!!! It wasnt loose i just barely pushed it and the a/c shut off. I didnt get a chance to fully check everything to make sure it all works great now, but i will at lunch .
Anyways im not sure the cause of this maybe faulty connector? or maybe road bumps loosen it up somehow.
Old Aug 12, 2009 | 11:00 AM
y0shi's Avatar
y0shi
the turbo probably burned a hole in your AC line. Pressurize the system and you will hear/see the area that is damaged.
Old Aug 12, 2009 | 12:54 PM
Chebosto's Avatar
Chebosto
i have both the same issues.. the AC not turning off, and no cold air.
1. i had a leak in my AC line near my driverside turbo
2. i think the white ribbon connector to the controller box was loose..
Old Aug 12, 2009 | 01:28 PM
Chomorro's Avatar
Chomorro
Well the loose white ribbon fixed my a/c speed control switch, but unfortunately not my vent selector switch. OH well i dont mind that too much.
You guys think a new white module is needed to fix these problems?
Old Aug 12, 2009 | 04:19 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
Thats what you get for having a boosted z...(I'm just jealous) on a serious note good luck with finding a solution
Old Aug 12, 2009 | 04:46 PM
ChrisR's Avatar
ChrisR
most likely the white ribbon. when i take off the shifter piece and disconnect it to get to the back of the radio it always blows out hot *** air! even on off
Old Aug 13, 2009 | 08:25 AM
tonester1011
CF God
well my ribbon going into the switches is really loose...if i hold it in the a/c turns off but still no cold air...i did find a pair of the control box and the new a/c amplifier white box for 80 bucks...so we'll see what happens after i put those in...i probably do have a leak somewhere too...i'll start with these 2 new pieces so at least the a/c will stay off without me holding the plug in...
Old Aug 13, 2009 | 09:30 AM
Chomorro's Avatar
Chomorro
New a/c amplifier box for that price. PMed i need to know where i can get one too
Old Aug 13, 2009 | 10:27 AM
tonester1011
CF God
not new...out of a junker
bjgordon
May 28, 2004 09:10 PM
Daytona Blue Z in Bo
Jan 27, 2004 04:58 AM
manrey
Jan 7, 2004 02:10 PM
emu29
Jul 16, 2003 07:51 PM
