emblem trouble....!
Old Sep 10, 2009 | 09:55 AM
Dark8lue's Avatar
Dark8lue
Default emblem trouble....!
so a friend of mine took his rear 350z bagde off and after waxing, it still left a little outline still in the clearcoat. anyway of getting this to come out? buffing perhaps
Old Sep 10, 2009 | 10:00 AM
gerryg2153's Avatar
gerryg2153
probably just a little glue residue
try some WD40 on a soft cloth
should clean it right up
Old Sep 10, 2009 | 10:15 AM
ParanoidAndroid's Avatar
ParanoidAndroid
This is a ghosting effect. where the emblems have been on the paint long enough in the sun.
You will need to take some rubbing compound and buff it out. If that won't help a little wetsanding and buffing is needed. If its an older model Z that has had those emblems on there for awhile your still gonna see the outline of the letters even with wetsanding and buffing at certain lights and angles.
Old Sep 10, 2009 | 12:09 PM
lgear080's Avatar
lgear080
paint should clear it up.
i know of what you speak as I just shaved the hatch on my 2003...
we painted it though.
Old Sep 10, 2009 | 12:21 PM
Z_flip's Avatar
Z_flip
it'll buff out =]
Old Sep 10, 2009 | 04:08 PM
Dark8lue's Avatar
Dark8lue
alright thanx for the advice...hopefully it all works out then i will do mine only if his doesnt **** up....BAAAHAHAHA
Old Sep 10, 2009 | 05:34 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
little bit of goo-off and then clean with soap and water and wax that area = done
Old Sep 10, 2009 | 06:02 PM
Dark8lue's Avatar
Dark8lue
yea a friend of mine has an ingredient called "oops" it took the gum somebody put on his hood off! not sure if it will work the same
Old Sep 10, 2009 | 06:09 PM
Kiriller's Avatar
Kiriller
sun shouldnt cause that much difference in paint color, try goo-gone. if that dosnt work, get a nice cutting pad and take off alittle clear coat around that area and your set.
Old Sep 10, 2009 | 06:58 PM
Dark8lue's Avatar
Dark8lue
yea he used an oil base of some sort and he still has clear lines where the emblem was. so now hes gona try and get it buffed out.
Old Sep 11, 2009 | 04:56 PM
slow_em2's Avatar
slow_em2
meguiers scratch x works good
Old Sep 11, 2009 | 05:22 PM
350ZthatsMe's Avatar
350ZthatsMe
rubbing compound w/ microfiber towel
Old Sep 12, 2009 | 01:45 AM
Dark8lue's Avatar
Dark8lue
i actually have some meguiers..will try this
Old Sep 12, 2009 | 04:48 AM
Dark8lue's Avatar
Dark8lue
if that dnt work im jus gona get my body shop to paint a lil over top of it
Siqcology
Sep 18, 2019 01:45 PM
hardkicks
Sep 20, 2015 12:28 PM
droideka
Jun 30, 2003 02:29 AM
travelmadness
Jun 19, 2003 10:47 AM
