Badge Replacement
Old Oct 27, 2009 | 02:50 PM
***Cadmium***'s Avatar
***Cadmium***
Default Badge Replacement
How easy to remove are the Nissan badges on the Z? The ones front and rear, only there are some copies on eBay UK that mimic the round circle but have a big Z in the middle.
I wondered if the badges just eased out ?
Old Oct 27, 2009 | 02:52 PM
Spork's Avatar
Spork
Pry out the wedges with the hammer knuckle via wire. Cut it through while sliding and you'll reveal the two post holes that will remain after removing.
Naw mean?
Old Oct 27, 2009 | 03:37 PM
diablox1's Avatar
diablox1
yaddaddamean?
Old Oct 27, 2009 | 04:18 PM
NismoZR's Avatar
NismoZR
Dental floss or thick fishing wire will do the trick and goo gone or wd 40 to get rid of the double tape .
Old Oct 27, 2009 | 05:17 PM
sluggoZ's Avatar
sluggoZ
www.activetuning.com/pat/4/2/
Old Oct 27, 2009 | 06:18 PM
sdZ33's Avatar
sdZ33
thick fishing line, goo-gone or wd-40, and (some don't really need to heat it up but it does help) and heat gun or blow dryer....
Soak the whole badge in goo-gone or wd-40 and let it set for a couple of mins...
Heat it up with a heat gun or blow dryer(this will get the glue a lil thinner)
Work the fishing line down from the top and work your way up from the bottom....
You might have to pry it after, because like the other guy said, it has two(2) guide posts on the badge... GL
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
pr_350z
Oct 1, 2015 05:03 PM
