HID lights help
Old Dec 20, 2009 | 10:37 AM
SHOCKWAVE77's Avatar
SHOCKWAVE77
Default HID lights help
I searched but couldn't find any thing on how to install a DDM HID Kit. Do anyone here know where I can find step by step instruction on how to install the kit? Thanks for any help!
Old Dec 20, 2009 | 11:24 AM
KornerCarver's Avatar
KornerCarver
Basically, you just need to remove your inner fender wells so you can access the back of the headlights. You need to find a place to mount the ballast. Then plug in the appropriate wires and you are good to go.
Old Dec 20, 2009 | 12:04 PM
SHOCKWAVE77
where is the best place to mount the ballast? I heard under the headlights is the best?
Old Dec 20, 2009 | 03:19 PM
KornerCarver
The stock ballasts are mounted in the headlight housing. Your aftermarket ballasts cannot be mounted there. Once you get your fender liners off, you should be able to see places where the ballasts can be mounted. The driver's side is easy. Since the windshield washer container is on the passenger side, mounting the ballast is a little more challenging. The whole process is pretty intuitive so you should be able to figure it out. Did you not get any instructions?
loudtoyz
Apr 6, 2023 04:52 AM
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
