350Z Partition....
Old Feb 1, 2010 | 02:17 AM
350ZTheStandard's Avatar
350ZTheStandard
They cost less with 2 convenient holes for 10 " sub woofers.
http://cgi.ebay.com/Nissan-350Z-Subw...item58808aa9eb
Old Feb 1, 2010 | 02:30 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Originally Posted by GHOST1207
Oh sorry, I forgot to tell you to scroll down.
I hope that's not the view your getting when you look from your driver's seat into the trunk...anyhow, I'll figure it out. Thanks.
Old Feb 1, 2010 | 03:32 AM
3FIDDYZED's Avatar
3FIDDYZED
If you dont have a sub enclosure then these are a really good idea.
Reduce road noise, stop stuff flying around and also make it harded for those with light fingers to see what you got in the boot!
Old Feb 1, 2010 | 07:29 PM
Spike100's Avatar
Spike100
I try to support our vendors, but I question the value of this. It appears to be a product whose offering would have benefited from some market research. Certainly it is a solution for some owners, but it could prove to be detrimental for others.
  • It reduces the already tight rear compartment in the Z. The Z’s strut bar is annoying when loading baggage into a coupe model, and adding a vertical barrier only aggravates the problem.
  • It robs the space some would use for a SubW installation.
  • It’s an expensive solution since a net barrier/holder (to keep small items you are transporting in place) provides the same value for much less $$.
  • It will reduce road noise from your rear wheels, but not so much. The Z’s road noise runs along the metal floor, and exhibits itself as a “noise leak” anywhere it can in the car. A sound deadening structure underneath the Z’s rear strut bar is of minimal value if the intention is reducing sound that is a result of road and tire noise. For example: The gap between the top of the rear strut bar and the Z's rear window allows a terric flow of noise that bounces from and runs along the hard surface of a window pane right to the driver and passenger seat. Ouch!
  • It won’t hide stuff in the rear section of your coupe any more than simply stuffing your gym bag under the rear strut bar, if in fact you even need to do this for a good “hide.”
My opinion is that this blocks loading stuff that might fit if the device wasn’t in place. I realize that it’s easily removed, but then where are you going to store it if you are away from your garage and need more cargo space?
--Spike
Old Feb 1, 2010 | 11:28 PM
GHOST1207's Avatar
GHOST1207
I'm pretty sure both sides look the same, unless one side has a picture of a girl bent over spreading her cheeks so that you can get a nice surprise everytime you look back.
Old Feb 7, 2010 | 07:11 PM
scparts's Avatar
scparts
Vendor - Former Vendor
Originally Posted by *ICE*
look nice but what if I need to carry stuff that require going underneath the strut bar? example, front lip which goes from the trunk to the center console.
Pop it out and lay it down....
It is purely friction fit, no modifications to the car at all....Very easy to remove and reinstall....
Jim
Old Apr 23, 2012 | 06:41 PM
pigpimpc's Avatar
pigpimpc
I love it! Stealth sub enclosure!!! Do you make this for 12's also?
Old Apr 23, 2012 | 07:14 PM
NISSAN-350Z's Avatar
NISSAN-350Z
thats a cool thing to have-very nice for example carrying few grocery bags that WILL slide around,i would probably put crap i buy in the passenger seat anyway plus the trunk is so small my cat carrier didnt even fit)))if i got one i want it to be there for sure and not fall every time i turn or stop
Old Apr 25, 2012 | 08:54 PM
bbs350z's Avatar
bbs350z
i need this, itll keep the gf from trying to climb back into the seat *stuffs head back in trunk*
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
