Fog lamp went out in front headlight
Old Feb 15, 2010 | 02:44 PM
westfl350z's Avatar
westfl350z
Default Fog lamp went out in front headlight
The fog lamp went out in my passenger headlight. Looked at different threads but can't find one that deals with the stock one's. Anyone know how to change them out?
Old Feb 15, 2010 | 03:03 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Light bulbs you will find in your headlight assembly (depending on which year you have):
Turn signal
Parking light
Low beam
High beam
Old Feb 15, 2010 | 03:06 PM
TheFarmer's Avatar
TheFarmer
You have a fog light inside your headlight?
Old Feb 15, 2010 | 03:19 PM
diablox1's Avatar
diablox1
Turn signal
Parking light
Low beam
High beam
+1
there is no such thing as stock fog lamps for 350Zs, much less inside your headlight.
to change any of those out, jack up the side of the car in question, remove (either all or partial) the plastic fender well liner, and you'll have access to all those bulbs.
Old Feb 15, 2010 | 03:35 PM
o2sys's Avatar
o2sys
i think he is talking about the parking lights the small bulb under the low beams.
i personally have removed them. Much cleaner look in my opinion. Plus the Z headlights regardless of year has the orange marker lights on the top so no need for two right?
NismoZR's Avatar
NismoZR
Like the guys said there is no fog lamps inside your headlight. If it is any of the bulb inside your headlight here is the link with pics that would help. http://www.350zmotoring.com/forums/d...ng-lights.html
Old Feb 15, 2010 | 03:36 PM
exZilaration's Avatar
exZilaration
Fog lamp in headlight?
Must be the UK spec lol
Old Feb 15, 2010 | 06:41 PM
westfl350z's Avatar
westfl350z
Thanks for the feedback everyone. It's the parking lights-the one's that turn on with the 1st turn of the headlight ****. I never have them on alone, but I figured I'd replace it anyway.
Old Feb 15, 2010 | 07:00 PM
BonesZ33's Avatar
BonesZ33
to change them lift up the inner plastic fender liner of the wheel well, its like a long rubber grommet that you twist and pull out and it holds the small bulb, very easy to replace.
Obadabot
Jun 18, 2023 11:31 PM
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
