Underbody guard/cover?
Old Feb 24, 2010 | 07:44 PM
NYCNYCNYC's Avatar
NYCNYCNYC
Default Underbody guard/cover?
was searchin for this topic but maybe I didnt look in the right place...so i just purchase a 07 350z touring roadster (LOVE IT LOVE LOVE IT)..anyways, running into a lil problem..my driveway/sideway has a lil ramp/hill on it and I have to come into my driveway at angle...Today, I guess i didnt angle it ENOUGH but i got a decent lil scratch under the right front frame...cant see it unless u look under but still
Is there anything I can put under or even on the front that can prevent this? like a sleeve?
Old Feb 24, 2010 | 08:26 PM
NYCNYCNYC's Avatar
NYCNYCNYC
Originally Posted by 350ZTheStandard
Listen junior, the car has a under body pan or tray, Nissan calls it engine cover lower
http://www.courtesyparts.com/74811-c...tml?cPath=714&
I think this is what u want, there just isn't a picture.
thanks i'll look into this but I got the scratch under the right side of the front frame...i guess i didnt "cut" it enough when exiting my driveway...
Old Feb 24, 2010 | 08:28 PM
winchman's Avatar
winchman
So, your car drags on a high spot in your driveway, and you want to add something under the car to keep the car itself from getting scratched. Sounds like a sacrificial rub strip, like they put on the bottom of some race cars. That might work, but attaching it could be a problem. It also increases the chance the car will drag on speed bumps, etc.
I suggest you put some strips of treated plywood on either side of the high spot to keep the car from hitting in the first place. You could attach the strips to the concrete or pavement with some urethane adhesive available at the home stores.
Old Feb 24, 2010 | 08:31 PM
NYCNYCNYC's Avatar
NYCNYCNYC
only problem I think with this suggestion...the whole entrance of the driveway is a steep lift..let me go take a picture of it
VO...'s Avatar
VO...
Administrator
Posts deleted. Let's start this over again...
VO
Old Feb 24, 2010 | 08:37 PM
NYCNYCNYC's Avatar
NYCNYCNYC
here is the curb (sry for the shitty pic. with my phone at 10pm mountain time)...pretty normal but like it cuts up...i live in arizona and we have driveways like this so no flooding (i think)
the scratch and what I want protected is the plastic part right directly below the front turn signal
Old Feb 25, 2010 | 08:52 AM
cheshirecat79's Avatar
cheshirecat79
i always wondered what neptune looked like through a high power telescope
Old Feb 25, 2010 | 01:00 PM
Pete5150's Avatar
Pete5150
Holy Crap! You're right!!!!
Old Feb 25, 2010 | 01:03 PM
0jiggy0's Avatar
0jiggy0
All kinds of fail here. You car is too low for your steep driveway, carry wood slabs with you. Case closed.
Old Feb 25, 2010 | 01:19 PM
Boostedtrack350's Avatar
Boostedtrack350
OP you will need the following items
1. Several bags on concrete
2. Something to mix the concrete in
3. Cold beer
Problem solved!
Old Feb 25, 2010 | 01:31 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
Bridge the gap
Old Feb 25, 2010 | 01:32 PM
Adon's Avatar
Adon
lol, you guys devour noobs on this forum, no mercy
NYC nothing you can do except park on the street maybe, or just hit up home depot for a few bags of smooth concrete mix, and a few beers like the other dude suggested.
I personally used flexible pieces of plywood I laid out in my alley garage and it worked fine, flexible enough not to break, and gave me the clearance I needed, maybe try that.
Old Feb 25, 2010 | 03:36 PM
Kelly_A's Avatar
Kelly_A
Try this
Old Feb 25, 2010 | 03:49 PM
DB350's Avatar
DB350
Originally Posted by Kelly_A
Got these, work good.
Close friend's father actually owns shercom too.
Old Feb 25, 2010 | 05:21 PM
350ZTheStandard's Avatar
350ZTheStandard
^ Where do you get these & how much $$$$$
Old Feb 25, 2010 | 05:30 PM
themadhatterxxx's Avatar
themadhatterxxx
That would be better if you could fold it up and take it with you wherever you go. I'm gonna patent a foldaway pontoon bridge for our cars.
Old Feb 25, 2010 | 05:31 PM
Russ@Z1's Avatar
Russ@Z1
http://www.shercomindustries.com/pro...curbramps.html
^^ Check here for your answer.
Old Feb 25, 2010 | 05:44 PM
DB350's Avatar
DB350
Most automotive stores where I live have them, some home depots, lowes etc too.
I think they were $30 a ramp
bluesaint
Jan 24, 2006 03:23 PM
Srivero297
Mar 11, 2005 06:22 PM
MacGyver
Feb 24, 2005 07:05 PM
Nismo3
350Z Roadster
Jan 16, 2004 09:19 PM
john350Z
Dec 31, 2002 11:03 AM
