Gauges
Old Mar 11, 2010 | 02:39 AM
tw8715's Avatar
tw8715
Default Gauges
http://intensepower.com/induortrfuap.html
so it says it can be modfied to fit 60mm gauges. do they do it.. or do i modify them once i recieve the product?
i wanted to put 2 60mm defi boost and oil temp gauges.. and one 52mm aem wideband.
Old Mar 11, 2010 | 04:10 AM
JasonZ-YA's Avatar
JasonZ-YA
yeah, mine said the same thing........
its just that they have a "lip" that you can get a dremel sanding stone to cut away at and make 60mm gauges fit in the hole.
no biggy....
-J
Old Mar 11, 2010 | 04:17 AM
JasonZ-YA's Avatar
JasonZ-YA
Also, take note that this is not an A pillar replacement? it goes over your current oem A-pillar and you will have to drill holes into your oem a-pillar in order to route wires through it.
Also, i found that the very bottom corner, i had to trim with my dremel to get the correct fit. once trimmed correctly you cant tell it was trimmed unless you hack off too much..
I didnt use those plastic plugs the come with....the bite........i used short self tapping sheet metal screws to install mine.
-J
Old Mar 11, 2010 | 04:34 AM
Z04's Avatar
Z04
why are you putting a boost gauge on a N/A car?
Old Mar 11, 2010 | 05:34 AM
JasonZ-YA's Avatar
JasonZ-YA
^ hes probably planning on going turbo....or purchaseing parts now or already bought everything......anywho....
I have a Boost gauge in an NA car - its just decoration of course...........my wife bought it for me saying "one day well buy you the turbo's you wan't, until then heres the first part" .........i was so happy..........she bought it on her own! means she was listening to all that car talk even though she was bored.....
cant knock that..........i have a good woman...
-J
Old Mar 11, 2010 | 05:48 AM
xzotklr's Avatar
xzotklr
-J
When I had it done it was a direct replacement. Wiring was routed behind the pillar.
I had to trim with my dremel to get the correct fit.
If installed correctly this is not necessary.
str8dum1's Avatar
str8dum1
^ you can knock that becuase a a boost gauge in a NA car is the biggest piece of RICE known to man.
just becuase you have it doenst mean you have to install it
Old Mar 11, 2010 | 05:53 AM
xzotklr's Avatar
xzotklr
so it says it can be modfied to fit 60mm gauges. do they do it.. or do i modify them once i recieve the product?'
In order to fit the 60mm gauges you will have to trim the opening. I used a Dremel with a grityy sandpaper drum. You take the Dremel and work the outer edge expanding it slowly. You will need to offset the opening slightly toward the "meaty" end (toward the pillar). Just take time and constantly test fit the gauge until it fits. Do not make the opening too large as the gauge will be held in place by the tight fit.
PM me if you have more questions.
Old Mar 11, 2010 | 06:38 AM
JasonZ-YA's Avatar
JasonZ-YA
just because you have it doesn't mean you have to install it
Well, i didn't install it, cause its you cant........but i mounted it....if i didnt, i would be letting my wife down.....and that aint happening bud..........
mind you i mounted it upside down cause I know some peeps that don't know the story would think "rice" so i mounted it upside down so people would ask "why" and then i tell them the quick story.... most understand....
-J
Old Mar 11, 2010 | 01:44 PM
tw8715's Avatar
tw8715
-J
lol she is a KEEPER!
Old Mar 11, 2010 | 01:45 PM
tw8715's Avatar
tw8715
hmmm so i guess i have to just order and try it out lol.
it will be disapointing if this aint a replacment and only a conver
Old Mar 11, 2010 | 07:36 PM
tw8715's Avatar
tw8715
anyone else know of some gauge pods that work well?
Old Mar 11, 2010 | 10:04 PM
10-E-C-350Z's Avatar
10-E-C-350Z
I just ordered a pod from a vendor on this site. I'll report back when it arrives if you can afford to wait a little while.
Old Mar 11, 2010 | 10:43 PM
tw8715's Avatar
tw8715
Good stuff! Mind sharing where u got it from??
Old Mar 12, 2010 | 12:32 AM
10-E-C-350Z
Well, I was going to keep that until I get it and check it out in case it was bonk, but if you insist. I got it from Dan@Assaultech. Thus far he has been VERY nice and appears to be quite knowledgable when it comes to the product he is selling. I was only going to get the gauge pod, but I think I will be doing the majority of my business through him. Just my .02
Old Mar 12, 2010 | 04:02 PM
Barnabas's Avatar
Barnabas
National Z Club President
let me know if anyone knows which one is a REPLACEMENT I can only seem to find covers..
Old Mar 13, 2010 | 09:46 AM
10-E-C-350Z
The one I ordered is a replacement according to what I was told. I asked a couple times to make double sure. I'll keep you guys posted...
Old Mar 13, 2010 | 01:57 PM
tw8715's Avatar
tw8715
If I think what I thought u got is the gauge pod they sell on their site. It's just a regular autometer gauge pod which it a cover not a replacement.
Hope it's something different. Let us know asap
Old Mar 15, 2010 | 12:36 PM
Barnabas's Avatar
Barnabas
I have the auto meter one now and at the bottom it doesnt even follow the OEM line it gets short and just lays there I hope you get a replacement one OP!!!
Old Mar 19, 2010 | 11:34 AM
10-E-C-350Z
Crap! Looks like I got kind of duped on this cover. I unwrapped it and discovered that it is in fact a cover. The same one Barnabas has. It looks like it covers the entire pillar though, so I guess it's not too bad. Without the car here with me it's impossible to see how well it fits to the existing pillar. So I guess the search continues...For the record, this does not mean the vendor I purchased this from is bad. Everything else I ordered from this dude showed up accurate, super quick and was wrapped with great care.
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
