New Headlights and Hid Kit
I was lookin to get some new headlights and hid kit. I was wondering if this would be good
http://www.dashzracing.com/Lighting-...-p5175641.html
I want the 8k kit
I want the 8k kit
The stock 350Z headlights are already projectors, so unless yours are damaged in some way, you don't need new headlights. I guess you might be getting it for the painted portion though.
Anyway, as for HID kits, I personally wouldn't go any higher than 6k, otherwise it will look too blue. 6k is perfect mix between blue and whie IMO. I have that color on my car and can post pictures if you're interested.
Also, I just got a cheap ~$60 HID kit off ebay, and it works great (had it for 3 years or so, no problems). I doubt the kit you'd be getting from the above link would be any better than the ebay kits.
You have a enthusiast model correct? You already have HID in the car. All you need is new bulbs, not the starter and ballast that comes with the kit. If you have a base then you will need the kit.
The reason I ask is because doing it by hand is just about worthless, but a buffer can work some magic.
What you can do is buy the cheapest ebay headlamps you can find, bake them, take off the front plastic lens, bake yours, open yours, paint yours (if you want), then replace your foggy/scratched lens with the ebay lens.
Or just use a buffer and see if you cant restore your lens.
Or buy some used OEM HID headlights that are in better condition.
damn i just wanted to be new and nice make it legit u know. So your saying those wont fit. Yes i polished it with a buffer and they are still lookin foggy. I really want black headlights and 8000k bulbs. idk what to do
http://cgi.ebay.com/ebaymotors/03-04...Q5fAccessories
Damn how do i make it COMPATIBLE lol i know ill **** somn up if i try oppening and parting out my headlight trying to take the lens off and yes i know quality is not the best on these aftermarket but i cant stand lookin at this foggy lens man!
There is nothing wrong with the headlights. They usually get dull and fogged up because of lack of maintenance. Here is a pic of my 2003 headlights and they are as clear as when they were new.
even if you have a base model z(in my case) you can still run HID's... i have HID highs and lows... swapped 3000k into the highs (for looks not functionality... phail i know) and i run 8000k for my running lights... just take your car to a shop that will know what you need to run the HID and they will set it all up... if you try to do it all your self you will get lost...
as for the ebay crap lights... i would suggest against it... i have heard some bad stories about those... look good at first but then shyt starts happening (moisture etc....) just find a nice set of USED OEMs to replace yours with... i just replaced my old set with a NEW OEM set directly from Nissan about a year ago. i also baked and painted the inside before i even installed them onto the car!
your headlights will change the complete appearance of the car so when you do it make sure to do it right... eBay lights from what i heard (NOT 100% SURE) just cant be trusted i guess...
if you do decide to get the headlights please keep us posted on how they hold up as im sure a lot of other people would be interested in swapping out if some actual ground work was done and noted.
HTH
HTH
forgot to mention... i have all aftermarket HID ballasts and love the look and color
crappy iPhone pix, would take a close up view pic but my car is in the shop but here is a fully painted housing
