Installed Recaro Pole Positions // Airbag lights on // Pic
Old May 9, 2010 | 06:46 AM
Germanguy's Avatar
Germanguy
Default Installed Recaro Pole Positions // Airbag lights on // Pic
Hi,
I have a 07 base model. I put my new Recaro Pole Position seats. Now I got this flashing airbaglight on my speedometer, that the airbags might not blow off after an accident. Someone knows what to do?
Thanks,
Alex.
Uploaded with ImageShack.us
Old May 9, 2010 | 07:27 AM
diablox1's Avatar
diablox1
do a searach for the airbag light reset procedure:
https://my350z.com/forum/3603538-post3.html
basically, it involves turning your ignition on/off a bunch of times.
Old May 9, 2010 | 07:28 AM
duro78's Avatar
duro78
Did you remember to reconnect the cable under the seat? if you did you might of yanked something loose
duro78's Avatar
duro78
Dont lie you just wanted to show off your new seats lol
Old May 9, 2010 | 07:39 AM
marques1's Avatar
marques1
+1 this will get the job done!!
Old May 9, 2010 | 08:14 AM
Armitage's Avatar
Armitage
Did your stock seats have airbags?
Old May 9, 2010 | 08:24 AM
FATPUBUS's Avatar
FATPUBUS
If the stock seats have airbags and these dont youre probably stuck with it on. In the passenger seat there is a gel bag that senses weight i beleive and if thats not in the new ones it wont go off. I swapped seats on my old Frontier and had the same problem and just lived with it. Good luck
Old May 9, 2010 | 08:56 AM
Germanguy's Avatar
Germanguy
Got the stock cloth base model seats.
Old May 9, 2010 | 08:57 AM
Germanguy's Avatar
Germanguy
My mechanic told me the same thing. This would be sh**. Is there no chance to solve this problem?
Old May 9, 2010 | 10:56 AM
terrasmak's Avatar
Some did yo have bags, you have to look.
Old May 9, 2010 | 11:35 AM
Chebosto's Avatar
Chebosto
if you have a YELLOW connection harness underneath the driver seat that is unconnected, you most likely have a seat-side impact airbag that you will need to trick the car to think that there is an airbag in place.. you will need a 2.0 ohm resistor to do that, then proceed with the airbag reset procedure.
if you don't have a side impact airbags, then it might be the weight sensor for your passenger side.. like the poster above, you will need to remove the air/gel balast sensor in the oem passenger seat and put it inside your recaro or tie it up.
Old May 9, 2010 | 11:36 AM
FATPUBUS's Avatar
FATPUBUS
Sharpie or black sticker lol... if ypu can get that gel bag off the psgr seat and put it in the new one with the electronic portion of it, the light should go off.
Old May 9, 2010 | 12:46 PM
Z33_kid's Avatar
Z33_kid
get the nismo air bag delete
Old May 9, 2010 | 12:50 PM
o2sys's Avatar
o2sys
isn't it a 3.3 ohms resistor?
Old May 9, 2010 | 03:19 PM
winchman's Avatar
winchman
For a second I thought you had installed the seats upside down. Then I noticed the steering wheel hanging from the roof.
Old May 9, 2010 | 03:38 PM
ChuckW's Avatar
ChuckW
Hi,
Those are some sexy seats!
Old May 10, 2010 | 07:20 AM
SargeZ350's Avatar
SargeZ350
There is a dummy connector that you have to mount on the oem harness so your light won´t pop up!
Sorry Guys!
Alex ruf Georg oder mich an!
Old May 10, 2010 | 07:27 AM
Ronin82's Avatar
Ronin82
I didn't even know the stock seats had airbags???
Old May 10, 2010 | 07:53 AM
SargeZ350's Avatar
SargeZ350
there should be written AIRBAG at the side of the seat!
When i installed my Pole Positions over 2 years ago the check airbag light came on several times. think i should redo the dummy
James1990
Dec 16, 2015 08:57 PM
nanotech
Oct 2, 2015 05:02 AM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
