removing old spray paint from interior
Old May 12, 2010 | 09:19 AM
JMSpeed's Avatar
JMSpeed
Default removing old spray paint from interior
My window switch covers were pretty nasty so I decided to refinish them. The passenger side came out alright, except the sand paper barely worked, therefore I had to use a knife which left streaks in the plastic. In the end they are barely noticeable but for the driver side I'd like to be more delicate.
The driver side was previously redone, but the prior owner did a ghetto job and I need to remove the old glossy black paint. Can I use a thinner without harming the plastic underneath? What about hitting it with steel wool first then a heavier grit sand paper?
Old May 12, 2010 | 09:54 AM
Ruthless18x's Avatar
Ruthless18x
So your saying, the original owner of the car spray painted the interior and you are going to clean it up, by spray painting it again?
You can find replacement pieces, wrap your current ones, or even go carbon fiber.
Old May 12, 2010 | 10:24 AM
cheshirecat79's Avatar
cheshirecat79
im confused
Old May 12, 2010 | 10:35 AM
06blueZ's Avatar
06blueZ
spray paint? did you buy your Z from this guy?
https://my350z.com/forum/exterior-and-interior/336575-all-interior-all-black-project-pics-inside.html
Old May 12, 2010 | 10:42 AM
JasonZ-YA's Avatar
JasonZ-YA
I would suggest having it wrapped........
Im going through this guy listed on my post #1 here:
https://my350z.com/forum/exterior-an...o-section.html
his work looks spot on, and i saw it in person through a friend local to me that had it done....
-J
Old May 13, 2010 | 03:40 AM
JMSpeed's Avatar
JMSpeed
1. Replacements will chip just as easily
2. I like the OEM look
3. See above
06bluez, your link does not work.
Thank you for all the suggestions. The passenger side after I refinished it is attached below. If I can get the paint off the driver's side, I'm going to paint it just the same. So you know, the previous owner taped off the switch cover and painted it while still in the car. It looks no where near my result. Is there still confusion?
Attached Thumbnails removing old spray paint from interior-img_0615-copy.jpg
Old May 13, 2010 | 06:11 AM
Ruthless18x
3. See above
Can't really tell from the picture. Take one of it installed. I have a feeling it's going to look out of place.
Old May 13, 2010 | 06:17 AM
JMSpeed's Avatar
JMSpeed
It looks good installed. I did it this morning and snapped some pictures. I will upload them when I return from class.
The color matches the interior trim almost perfectly if not perfectly.
EDIT: That black line in the picture is an error from resizing the picture in paint.
Old May 13, 2010 | 08:33 AM
JMSpeed's Avatar
JMSpeed
1st pic: passenger side refinished
2nd pic: driver side as it is
I could go more black if I found the right paint I guess.
Attached Thumbnails removing old spray paint from interior-img_0617.jpg   removing old spray paint from interior-img_0620.jpg
Old May 13, 2010 | 08:44 AM
Brrcats's Avatar
Brrcats
man I wish I had cupholders in my doors
Old May 13, 2010 | 08:48 AM
3. See above
A solvent such as mineral spirits is detrimental to plastic. You have little choice but sanding.
Old May 13, 2010 | 11:12 AM
JMSpeed's Avatar
JMSpeed
Believe me, they don't hold anything useful to drink unless you are a canned soda junky or alcoholic. You aren't missing out.
That's what I feared. I might try a brill-o pad since I need some anyway for my CEL fix.
Thank you guys.
Old May 13, 2010 | 02:27 PM
Voboy's Avatar
Voboy
the passenger side turned out very nice. looks oem
Old May 14, 2010 | 03:19 AM
JMSpeed's Avatar
JMSpeed
Thanks
I picked up a different brand (Duplicolor) and will try the drivers side with it. If it's darker I might make a couple pases on the passenger side. The goal is oem look
Old May 14, 2010 | 11:26 AM
zerafian's Avatar
zerafian
wtf you have a cup holder...is that an 06+ feature or something?
Old May 23, 2010 | 04:39 PM
OkashiZ's Avatar
OkashiZ
yeah it is. i have one in my 06 MB GT
3vilbunny
Jul 18, 2017 05:10 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
