Automatic lights???
Old Feb 2, 2005 | 04:05 PM
bio911's Avatar
bio911
Question Automatic lights???
I forgot to check and see if the 350z had automatic lights. By that i mean does it have a setting to sense if it is dark and turn on the lights automaticly?
Old Feb 2, 2005 | 04:12 PM
Jun's Avatar
Jun
no. but they turn off by themselves when you leave them on by mistake and the car isn't on.
Old Feb 2, 2005 | 09:44 PM
barthelb's Avatar
barthelb
Master
I was wondering the same thing. The G has it. So wouldn't it be as simple as a fuse or something? I will look into this later.
Old Feb 3, 2005 | 07:43 AM
drift350's Avatar
drift350
you need the light sensor.
Old May 20, 2010 | 04:55 PM
temoku's Avatar
temoku
anyone ever put in an aftermarket light sensor system? I absolutely hate turning on my lights manually, this is the only car I have ever owned that I had to turn the lights on manually. I know there are aftermarket kits out there, I just need to find one
Old May 20, 2010 | 05:15 PM
DavesZ#3's Avatar
DavesZ#3
Wow. 5 year old thread bumpage.
Check kptechnologies.com they make all kinds of goodies for the Z & G along this line.
Old May 20, 2010 | 05:35 PM
kevincat's Avatar
kevincat
you can go to your local dealership and tell them to reprogram the lights to go off a few seconds after the car is off instead of the usual 5 minutes.
it should cost you 70-90 dollars
Old May 20, 2010 | 06:06 PM
DavesZ#3's Avatar
DavesZ#3
He wants truly automatic lights, on when dark, off when light, all without using the switch.
Getting them reprogrammed and leaving the switch set to ON would cause them to come on every time he starts the car and go off shortly after removing the key. Not exactly the same thing.
Old May 23, 2010 | 05:53 PM
temoku's Avatar
temoku
yea even my toyota camry had light sensing automatic lights
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
