06+ Headlights - swapping small side parking lights
Old Jul 12, 2010 | 07:47 AM
RA11725's Avatar
RA11725
Default 06+ Headlights - swapping small side parking lights
I'm trying to change my parking lights from yellow to white to match with the low/highbeams for a nice clean look. So far I've swapped the larger parking lights (168's, below the low/highbeam) to white Putco LED's, but I have no idea how to swap the four small yellow LED's that run up the side of the headlight above the low/highbeam. I called CinCity Designs and they said I had to do something with the circuit board, and that it is "a pain in the nuts". Has anyone modified these lights before?
Old Jul 12, 2010 | 07:52 AM
quakerroatmeal's Avatar
quakerroatmeal
I believe they're soldered onto the circuit board. Meaning it will not be easy to change.
Old Jul 12, 2010 | 07:57 AM
RA11725's Avatar
RA11725
So if I wanted to make them white, I would have to open up the housing to get to the circuit board, take the old lights off the board and solder in the replacement lights? Any idea on what bulb they are?
Old Jul 12, 2010 | 09:11 AM
Blck350z's Avatar
Blck350z
Agh.... I just painted my headlights last night..... And yes they are on a circuit boad that can be de-soldered and have new ones re-soldered.... I would've taken pictures but I was getting tired so I just threw them back together.... But its not an easy "take out and slap new ones in" kinda thing. Good luck with everything.....
Old Jul 12, 2010 | 09:43 AM
RA11725's Avatar
RA11725
Cool, thanks man. So you didn't mess with the lights at all, you just painted the housing right?
How are the turn signals doing since you painted the housing? I'm worried there won't be any reflectiveness!
Old Jul 12, 2010 | 10:08 AM
BoomerZ33's Avatar
BoomerZ33
I think the amber parking lights against semi-flat black housing looks pretty cool imo. I just got my headlamps blacked out by Lightwerkz. I was contemplating whether to change the parking lights to white LEDs as well but the installers there told me it's complicated and would involve circuit board soldering.
Old Jul 12, 2010 | 10:13 AM
RA11725's Avatar
RA11725
OK, what about the turn signals though? I'm thinking in terms of safety (legality, really). I don't want to get pulled over because my turn signal bulbs aren't reflecting off the housing, thus not being noticable enough.
As for the circuit board soldering, a friend of mine just did some of that two days ago so he's got a gun and plenty of solder. It will be a project but I might as well do both while I'm in there!
Old Jul 12, 2010 | 10:40 AM
BoomerZ33's Avatar
BoomerZ33
i don't think you'll get pulled over because of the lack of amber reflection. As long as the light is clear and visible from a distance you should be good. Here in NJ no cops care as long as they blink amber
Old Jul 12, 2010 | 11:22 AM
Guilty1s's Avatar
Guilty1s
Once you get the case open, an easy 4 3mm leds to solder.
Old Jul 13, 2010 | 09:41 AM
theleonard350z's Avatar
theleonard350z
Yeah man i wouldnt even mess with it... work on the wheels first. lol
Old Jul 13, 2010 | 12:00 PM
Blck350z's Avatar
Blck350z
The 06+ lights are extremely bright... as the projectors don't use the reflective housing and the LED turn signals are bright by themselves.... the only thing I have to get done is re-align my head lights..... I'll take pics and post them here tonight if you don't mind
Old Jul 14, 2010 | 06:49 PM
RA11725's Avatar
RA11725
OK cool, thanks man. This should be a fun project.
Mine are a little crooked as well, are you re-aligning them yourself? If you are, please send me some info on how to do it. Thanks man.
Yea I agree that's a little more important lol I started this thread before the mishap. Just a little project to keep me occupied. Anyway, see you tomorrow dude.
Old Oct 29, 2010 | 06:24 AM
trucutu62's Avatar
trucutu62
I just orders the parts I need to mod my 06 headlights...sti clear projector lens, halos, demon eye LEDs and I'm also going to attemp to change the led from the circuit board.
Old Dec 16, 2012 | 10:57 AM
daniel123588's Avatar
daniel123588
Really old thread but i just got around to changing the 4 leds on the corner since there are no threads on here in regards to changing them. Each amber LED runs 2.5 volts and there is 4 resisitors soldered on to the board. Super easy work for someone that knows about leds and using a multimeter. I ended up using four 5 mm white leds. And also from the looks of it, it not a 3 mm, the led head has a weird shape and not like the typical leds you see for purchase. Its kind of like a flat headed LED but with a round tip in the middle.
Im actually quite surprised that people at these headlights retrofit businesses didnt want to tackle this one. Easy money for them.
Old Dec 16, 2012 | 11:31 AM
amr_electron's Avatar
amr_electron
A direct replacement LED boards are also available from ledmarkers, $40/pair .
Old Dec 16, 2012 | 02:03 PM
daniel123588
Damn thats a pretty good deal! It seems hes even has superflux type leds mounted too. Looks like you got a nice projector in the turn signal, hmmmmm i gotta look into that when i open the headlights again...
Thanks AMR Electron that should be super helpful for people on this forum if they can find this thread that is hahaha
Dsowe
Feb 17, 2021 10:38 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
