Very very quick question
Old Aug 26, 2010 | 10:20 AM
JDMStanced's Avatar
JDMStanced
Default Very very quick question
I'm ordering D2R light bulbs for my 05 350z. Are the D2R light bulbs used for when driving on days? Since i have manual on and off headlight switches, if i turn off the headlights in the morning, the D2R bulbs are not used; if i turn on the headlights at night, the D2R bulbs are used, am i correct?
After installation, if i turn on High beam or low beam, just stock high and low beam light bulbs go on?
Old Aug 26, 2010 | 11:05 AM
diablox1's Avatar
diablox1
doesnt make sense. if you're just replacing bulbs, functionality should be identical as before; nothings changed.
Old Aug 26, 2010 | 11:08 AM
JDMStanced's Avatar
JDMStanced
Cause you know there are different types of bulbs-high beam bulb, low beam and etc.
So i wonder which bulbs D2R replace with?
Old Aug 26, 2010 | 11:46 AM
User 42426's Avatar
User 42426
There is only one bulb for the headlight, either d2r or d2s. From my understanding, to turn on the high beam, there is a rod that moves to enable more light output, and it goes back over the bulb to reduce intensity. So you are using the same bulb for all the light emitted, its just covered slightly or less to emit more light.
So to answer your question, the d2r bulb itself does not replace your parking light, turn signal light, high beam, or low beam light. It is just the main headlight bulb which can be manipulated to be the high beam/low beam/normal driving.
Old Aug 26, 2010 | 12:10 PM
JDMStanced's Avatar
JDMStanced
thx guys for your answers!
Old Aug 26, 2010 | 12:34 PM
bmccann101's Avatar
bmccann101
Default lights.
This information above is correct for 2006 and up cars, but is NOT correct for your 2005.
The 2005 uses a halogen for the high beam, and the D2 HID is for low beam only. The hi beam is located unde the projector housing.
Using the term daytime and night time doesnt make sense to describe the two btw, but i didnt see your location.. maybe they say it different in your part of the world.
The 2006 headlight uses a mechanical flap in side the projector to cut off the top of the light beam of ONE single bulb.. and moves to allow hi beam light from this same bulb.
2005 headlights have 2 different static bulbs. Only the low beam can be HID.
Old Aug 26, 2010 | 12:42 PM
JDMStanced's Avatar
JDMStanced
When i turn on the headlight to ON, does the low beam go on?
I ordered a pair of D2R but now i'm thinking if i need a pair for high beam also.
Old Aug 26, 2010 | 12:50 PM
bmccann101's Avatar
bmccann101
Default :)
i hope youre not American.. haha.
Yes when you turn your headlights on, the HID turns on. Your bright beam is Halogern and only works when the light paddle is pushed fwd.. They VERY RARELY burn out tho, and to have 2 burnt out is VERY strange.
There is an "undocumented" fuse box behind your battery . You must take ALL the plastic off around the battery to see it..
there are fuses there for the headlights. Id check that first before spending a single dime on lights.
its undocumented becuase most people would take the carr to a dealer for 100 bucks to have them do it when they cant find the fuse.. pretty crooked if you ask me, but hey, at least we all found the damn thing now.
Old Aug 26, 2010 | 01:25 PM
It is helpful if you put a subject in the subject line.
Old Aug 26, 2010 | 01:30 PM
JDMStanced's Avatar
JDMStanced
"Yes when you turn your headlights on, the HID turns on. Your bright beam is Halogern and only works when the light paddle is pushed fwd.. "
This was the straight forward answer i was looking for lol
Old Aug 27, 2010 | 10:31 PM
SageZ's Avatar
SageZ
Old Aug 28, 2010 | 03:10 AM
Z04's Avatar
Z04
the same answer you could have found by reading your owner's manual as well
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
