Headlights Are Flickering HID
Old Aug 26, 2010 | 12:17 PM
350zJDMnismo27's Avatar
350zJDMnismo27
Unhappy Headlights Are Flickering HID
So when I drive with my headlights on they some times flicker then go out. So I have to turn switch off then back on(sometimes multipul times for them to come back on)... When there is the slightest little bump or vibration it casues them to flicker or go out..Is this bulbs? I checked the connection to the ballast and etc and there all fine..
Let me know
Thanks
Old Aug 26, 2010 | 12:39 PM
ChrisNelson's Avatar
ChrisNelson
OEM or aftermarket? I'm guessing aftermarket.
That's what you get for a $50 HID kit...
Old Aug 26, 2010 | 12:59 PM
kevincat's Avatar
kevincat
one side or both side? oem hid or aftermarket?
Old Aug 26, 2010 | 01:15 PM
350zJDMnismo27
OEM and left more than the other but still there both almost the same
Old Aug 26, 2010 | 01:26 PM
Waiz's Avatar
Waiz
Maybe this would help if you already checked the ballast:
https://my350z.com/forum/g35-g37/475...lickering.html
Good luck.
Old Aug 26, 2010 | 01:46 PM
Most likely:
Bad bulb
Bad ballast
Bulb is not properly grounded. The connector on the bulb is corroded. Most likely water.
Old Aug 26, 2010 | 02:38 PM
350zJDMnismo27
Thing is when I sit and idle there fine its only when I drive
Pleask
Dec 21, 2021 03:17 PM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
