OEM HID flickering
Old Feb 14, 2010 | 07:47 PM
VeeTec's Avatar
VeeTec
Default OEM HID flickering
Guess I am taking the lazy route, but has anyone corrected this problem? I am thinking it could be the bulb, ballast or igniter. What a pain.
The problem is quite random and usually settles down, only to return later. This is on a 2004 G35 Sedan.
Old Feb 14, 2010 | 10:27 PM
smellyborrelli's Avatar
smellyborrelli
probably bad grounding somewhere.
Old Feb 15, 2010 | 06:15 AM
CeBrwn5454's Avatar
CeBrwn5454
I had the same problem on my 04 Coupe.
Take the headlight out and check the yellow grounding wire inside the light. Mine was loose...got a pair of tweezers and made it tight again...no problems.
Old Feb 15, 2010 | 02:16 PM
VeeTec's Avatar
VeeTec
Thanks, will do and post back!
Old Feb 26, 2010 | 03:17 PM
bknewtype's Avatar
bknewtype
i have the same exact problem on my driver side. flickers then goes dead. im pretty sure its the ballast for my problem. maybe i shoudl check the yellow wirigntoo. did u ever find otu about yours?
Old Mar 2, 2010 | 12:11 PM
VeeTec's Avatar
VeeTec
Not yet. I have to pull off the front bumper and I haven't really had time. The problem has been intermittent. I noticed that bumps and slowing down seem to make it worse or start up so I assume it is a connection.
Old Mar 2, 2010 | 12:42 PM
Adon's Avatar
Adon
check all your fuses, i had the same issue and turns out one of my fuses was blown.
there are 3 fuse boxes in your car, 1 beside the clutch or brake, one right behind the battery, and the last is behind in a secret compartment also above the battery
Pleask
Dec 21, 2021 03:17 PM
350z82
Oct 1, 2015 06:25 PM
