Window Question!?!?
Old Nov 13, 2003 | 07:44 AM
lemonjihwan's Avatar
lemonjihwan
Default Window Question!?!?
all the Z's window rolls down a little when they open the door... and when you close the door it goes back up...
and when i get my Tint... then what am I suppose to do? when i get my tint, im not suppose to open the window for like...a week at least... help please.
thanks
Old Nov 13, 2003 | 07:47 AM
devildogg's Avatar
devildogg
Tint away! Won't bother it at all.
Good Luck!
Old Nov 13, 2003 | 07:49 AM
lemonjihwan
Question
tint away????
Old Nov 13, 2003 | 04:03 PM
kbomb's Avatar
kbomb
The window goes down a tiny bit when opened...when closed it goes up to seal it.
I had my car tinted and they charged a alot because of this...basically they open the door,,block the sensors so the window stays up and wont roll down and tint the whole window.
check it out and sign my guest book
http://members.cardomain.com/kbomb78
Old Nov 13, 2003 | 05:02 PM
Grimtek's Avatar
Grimtek
had my tint with no prob, they jus said don't roll it up or down for abt 3 days
Old Nov 13, 2003 | 05:47 PM
lemonjihwan
but it rolls down and up by itself tho'
Old Nov 13, 2003 | 05:54 PM
ares's Avatar
ares
Veteran
couple parts have been said here.
first off DURING the tint job, the door would be open, meaning the window is down a little, meaning they have to tint an inch or so below the seal. this can be done by just pulling the seal back and putting the tint down in there, or remove the door panel and seal. the latter is more difficult, but IMO seems better as you can clearly get all of the glass.
the second part, first off by doing the previously mentioned part, there is a minimal amount of rubbing since the seam is below the seal, and thus it wont catch. but as for the top edge, they need to use a heat gun to dry it 90% of the way. it wont slide or roll that easily then.
Old Nov 13, 2003 | 05:57 PM
lemonjihwan
ares : Thank you!
Old Nov 14, 2003 | 10:37 PM
Wedge's Avatar
Wedge
The two methods given for getting the tint on the side windows when the door is open is a lot of extra work. All that needs to be done while the door is open to get the window back up is to have someone hold in the button on the door frame. This simulates the door being closed and the window is then fully raised while the door is open. They can put the tint on the side windows fairly quickly so the button doesn't have to be held in for a long time.
issyz
Jul 2, 2017 03:04 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
Alexreyes
Sep 30, 2015 11:30 PM
