Extinguisher revisit
Old Sep 6, 2010 | 04:58 PM
Tackett's Avatar
Tackett
Default Extinguisher revisit
Ok. Long story short. Driving around yesterday and one of the wires to an amp came loose and fell into the back of the car where I couldn't get to it.
It started arching and smoke started BILLOWING out of the back.
I made a mad dash pulling everything out trying to find the wire before something caught.
All in all. I found the wire, put everything back, rewired securely. No harm done, but could have been way worse had something taken to the spark or I wasn't around when it happened.
I want to get an extinguisher. I'm aware that they won't do anything for engine fires, but for small electrical fires, I don't think it could hurt to have one handy. Though I have a couple ideas where to mount it, I want to see if anyone has any suggestions of somewhere out of the way, but stil accessible.
I know this has been hashed over a few times. But the threads I read only had a few pics, but were mostly people flaming about how pointless it is yada yada.
No flaming this time. If you think it's dumb, that's fine, just ignore this thread. But if you have some good suggestions post em up!
Thanks.
Old Sep 6, 2010 | 05:05 PM
mike5411's Avatar
mike5411
could the extinguisher do damage to the amp if it was sprayed?
Old Sep 6, 2010 | 06:11 PM
DavesZ#3's Avatar
DavesZ#3
I can't remember the brand name, but there is some kind of extinguisher out there that a lot of the racers are using. It doesn't ruin everything when you use it like the dry chemical ones will do. No residue, etc. You definitely want to look into something like that.
Old Sep 6, 2010 | 06:18 PM
Tackett's Avatar
Tackett
Good idea. I didn't know they made something like that. I'll spend some time with google and post what I come up with.
Old Sep 6, 2010 | 06:56 PM
dcains's Avatar
dcains
What you may want is a Halon extinguisher. Ever hear of fuses?
Old Sep 6, 2010 | 07:28 PM
Tackett's Avatar
Tackett
Fuse did not blow for some strange reason.
It was the distribution block, so the main fuse should have blown, but it didn't. dunno why.
Old Sep 6, 2010 | 07:41 PM
Tackett's Avatar
Tackett
http://halonfireextinguisher.net/
Old Sep 7, 2010 | 08:18 PM
Michla22's Avatar
Michla22
Mine's under the passenger seat - out of the way and easy to get to.
Old Sep 7, 2010 | 08:24 PM
Tackett's Avatar
Tackett
Does it affect moving the seat? Looks nice.
Old Sep 7, 2010 | 08:29 PM
zer0cool's Avatar
zer0cool
It should have blown the fuse when it made contact and arched the first time unless your running fuseless power wire to the rear correct?
Michla22's Avatar
Michla22
Using the sparco seat bracket that came with the seats - no rubbing or anything , can move the seat fine.
Old Sep 7, 2010 | 08:34 PM
Tackett's Avatar
Tackett
There's a fuse. It was from the power distribution block, should have blown the main fuse, but it did not.
I may mount it where he did under the passenger seat. Nice spot, looks good.
Old Sep 7, 2010 | 09:18 PM
dcains's Avatar
dcains
Use a smaller fuse(s). Obviously what's in place is providing zero protection.
Old Sep 7, 2010 | 09:55 PM
Tackett's Avatar
Tackett
Wow...this is embarrassing.
I just checked the fuse block....
I ummm....put a direct connection in it a while back to test something...and I guess I never put the fuse back in.
Oops.
Old Sep 8, 2010 | 08:24 AM
BoomerZ33's Avatar
BoomerZ33
derr. you should still get the extinguisher
Old Sep 8, 2010 | 02:42 PM
aloh's Avatar
aloh
Oops.
Good thing that little incident didnt end up worse!
Put a proper fuse back in there
Old Sep 8, 2010 | 04:15 PM
JDMStanced's Avatar
JDMStanced
i was going to use install the extinguisher used for stores, the red ones lol..
Old Sep 8, 2010 | 04:54 PM
Tackett's Avatar
Tackett
Proper fuse placed back in.
Whew. That was stupid.
Old Sep 8, 2010 | 06:38 PM
Mr. D's Avatar
Mr. D
I keep an extinguisher in the cargo net.
Old Sep 8, 2010 | 06:46 PM
JasonZ-YA's Avatar
JasonZ-YA
I made my own custom mount under the passenger seat........its dry chem and yes will require clean up, but you can mount a halon under there.....
I also have a Halon extinguisher on the harness bar i made:
DIY THREAD:
https://my350z.com/forum/body-interi...highlight=fire
-J
