Plasti-Dip Questions & Projects Thread
Old Apr 19, 2014 | 10:18 AM
  #561
frocker93's Avatar
frocker93
They kinda look like something off of a hot wheels car.
Old Apr 19, 2014 | 12:01 PM
  #562
SR71's Avatar
SR71
Lead Super Moderator
Id have to see them on the car, needs to be a black Z for sure though.
Old Apr 19, 2014 | 12:10 PM
  #563
mr. sparco's Avatar
mr. sparco
I want to see fully dip'd Zs!
Old Apr 19, 2014 | 12:34 PM
  #564
CJM's Avatar
CJM
350z World Rally Blue- http://www.dipyourcar.com/forums/sho...highlight=350z
350z 5 color Chameleon- http://www.dipyourcar.com/forums/sho...highlight=350z
350z Satin Black- http://www.dipyourcar.com/forums/sho...highlight=350z
350z Blue/Green Chameleon- http://www.dipyourcar.com/forums/sho...highlight=350z
350z Black/Blue- http://www.dipyourcar.com/forums/sho...highlight=350z
350z Candy Purple- http://www.dipyourcar.com/forums/sho...highlight=350z
370z Anthracite- http://www.dipyourcar.com/forums/sho...highlight=370z
370z Orange- http://www.dipyourcar.com/forums/sho...highlight=370z
Old Apr 19, 2014 | 01:39 PM
  #565
SQuaLZ's Avatar
SQuaLZ
Just finished my B13.
Before...
During...
After... Plus a pic of the new shift **** for it.
Old Apr 19, 2014 | 01:42 PM
  #566
SQuaLZ's Avatar
SQuaLZ
It took about 3 hours and 6 cans. I will eventually redo the trunk and roof but for my beater I'm very happy with the finished product. However, I would never do this to my Z.
Old Apr 19, 2014 | 02:06 PM
  #567
CJM's Avatar
CJM
With only using 6 cans, it may not peel off too easily
Old Apr 19, 2014 | 02:38 PM
  #568
mr. sparco's Avatar
mr. sparco
I actually didn't, was being facetious. Saw a couple at the last local meet and they both looked like poot up close. No offense squalz. lol
Old Apr 19, 2014 | 03:04 PM
  #569
SQuaLZ's Avatar
SQuaLZ
I don't plan on taking it off.
Old Apr 19, 2014 | 03:06 PM
  #570
SQuaLZ's Avatar
SQuaLZ
I would say only really 2 spots I didn't like the finish. The paint was shot on the car and wanted a cheap fix. Put alot of effort though, so overall I would say it was a success.
Old Apr 19, 2014 | 04:38 PM
  #571
_stickerz's Avatar
_stickerz
Here is a little plasti-dip and lambo racekor action from this afternoon. Wrap took us 9 hours to complete, dip took 15 minutes, lol.
Old Apr 19, 2014 | 10:12 PM
  #572
Dustin Wood's Avatar
Dustin Wood
Lol good thing they're mine and not yours.
Old Apr 28, 2014 | 03:11 PM
  #573
justjusten's Avatar
justjusten
Default Shift **** Plasti dip color change
Warning: Grammar was not my best subject. I can make corrections though.
This is where its at as of now
I know it's not perfect but I think it looks a lot better when I started working on it.
I picked up a slightly worn oem shift **** from my friend that was light gray and had been painted silver on the sides. It wasn't really my thing so I decided to see if I could make it black. Unfortunately I didn't take pictures of the **** before I started. I decided to give plasti dip a try because if I screwed up hopefully it would pull off of the leather.
Here is a pic of most of the stuff I used, I forgo to put the sand paper, tooth picks, q-tips and paper towels in the picture.
I found this thread http://www.8thcivic.com/forums/diy-h...ternative.html and worked off it. I might epoxy like the guy on that forum did but I haven't decided yet.
The first thing I did was to clean the **** and then wipe it down with an acetone soaked rag. I then flipped it over and dipped it into the plasti dip container (you can cut and peel it off the areas you don't want it). The container says to go down an inch every 5 second and I tried to follow that. Try not to bump the sides when pulling it out because it will disturb the surface of the **** causing lumps. It comes out looking pretty uneven but it manages to really level itself out pretty well. I did two coats (on separate days) and it came out looking pretty good but needed one more coat for a couple bad spots.
I would suggest trimming it off the metal parts between coats. I did this on the bottom only and it was difficult to get a decent cut on the top piece when trying to cut through two layers.
Next I taped off the dipped part (It would probably be smarter to do this before dipping) and got to work removing chipped paint from the metal with 500 grit sand paper and then 1200 grit sandpaper.
I tried to only move the paper horizontally to get a brushed finish but I ended up not being happy with how curvy my scratches were.
To make it look better I took rubbing compound ( metal polish might work better but I didn't have any) and a dremel polishing tip and buffed it out. With more work you could get it all the way to a mirror finish but that was not what I really wanted.
To fill the shift numbers in I used wax from a crayon ( I heard it can melt out over time but I'm not terribly concerned because I might put epoxy over it.) Make sure to clean the the grooves out really well before trying to fill it. I didn't the first time and the color had dark spots. I then used a tooth pick and a curved tip x-acto knife to pick any gunk out of the grooves. after I had it nice and clean I dipped a q-tip in acetone and cleaned the grooves of any left over gunk. I then took the crayon and kind of colored over the indention. I tried to kinda treat it like a cheese grater and scrape the wax into the groove. Keep going until its pretty much filled up, it should look pretty messy with excess wax all around the numbers. Next I melted the wax with my hot air attachment of my soldering iron but I think a hair dryer, hot air gun, or even lighter( if your careful) would work fine. Try not to heat the plasti dip too much. After the wax in the cracks was obviously melted together and smooth I took a paper towel and rubbed the excess wax off from around the numbers.
If any of the lines where the excess plasti dip was trimmed off are not in great shape you can dip a q tip in mineral spirits and run it over the edges or any other blemishes. It seems to kind of remelt the plasti dip and can smooth edges. Feel free to ask any questions and I'll try to answer them. If I decide to epoxy it, I will add that to the guide as well.
Link to imgur gallery http://imgur.com/a/Sc2qU with a few more pictures.
Old Apr 29, 2014 | 05:33 AM
  #574
dcains's Avatar
dcains
Actually think it looks OK, but here in FL, that wax would be melted and dripping down the **** even before the real hot time of year gets here.
Old Apr 29, 2014 | 10:31 AM
  #575
justjusten's Avatar
justjusten
Yeah I live in Georgia, Im definitely going to epoxy it before I put it in the car if I decide to keep the wax. If not I might just get some enamel paint.
Old Apr 29, 2014 | 05:45 PM
  #576
sry110's Avatar
sry110
Before:
After, with 5 coats of Plastidip aluminum true metallic color and 2 coats of glossifier:
Old Apr 30, 2014 | 11:17 AM
  #577
Bmurray350z's Avatar
Bmurray350z
Old Apr 30, 2014 | 04:36 PM
  #578
sry110's Avatar
sry110
^ Looks great! I'm convinced now that plastidip can provide very nice looking results when the proper prep work and adequate amount of smooth coats is applied.
Old May 21, 2014 | 09:46 AM
  #579
renzodem's Avatar
renzodem
Old Jun 22, 2014 | 07:38 AM
  #580
alvy350z's Avatar
alvy350z
Default dipp
Well since it seems everyone hates plastidip lol heres my car dipped...
Attached Thumbnails Plasti-Dip Questions & Projects Thread-1385246_751907094848370_3122587673576961392_n.jpg   Plasti-Dip Questions & Projects Thread-10271487_751907068181706_816226562353057066_n.jpg
