Plasti-Dip Questions & Projects Thread
Old Sep 18, 2011 | 05:57 PM
  #161
350Speed's Avatar
350Speed
I used plastidip before and same thing happened to me once. I just peeled it off and repainted it.
Old Sep 18, 2011 | 06:22 PM
  #162
moose350z's Avatar
moose350z
Peel and respray.
Old Sep 18, 2011 | 06:41 PM
  #163
Waiz's Avatar
Waiz
NOTICE
I have merged the three active Plasti Dip threads into one thread for your questions/projects to be placed into.
Let's make sure to keep any additional posts here rather than creating another thread.
Old Sep 18, 2011 | 08:35 PM
  #164
mr. sparco's Avatar
mr. sparco
Some dippage.
Old Sep 18, 2011 | 09:44 PM
  #165
Itzcashew's Avatar
Itzcashew
How do i hold down my dog to plastidip him?
Old Sep 19, 2011 | 02:50 AM
  #166
Gumby Gone Wild's Avatar
Gumby Gone Wild
Old Sep 19, 2011 | 06:59 PM
  #167
SilverZ350's Avatar
SilverZ350
Some dippage.
Questions for you, did you have any trouble when peeling off your masking tape and the plastidip peeling with it due to over spray? I had this happen to me, I am new to this, guess I could of used a spatula or something?
Old Sep 20, 2011 | 06:12 AM
  #168
sluggoZ's Avatar
sluggoZ
Thanks guys! You made me laugh today! Name:  woot-1.gif
Old Sep 20, 2011 | 10:20 AM
  #169
sum1finally's Avatar
sum1finally
no just take off the tape before it dries
Old Sep 20, 2011 | 10:31 AM
  #170
Waiz's Avatar
Waiz
What I was told recently from someone who PD'd their emblems is that if you use a few strips of painters tape around the area rather than larger pieces it is easier to remove.
I would suggest using a criss-cross pattern with a few strips at the edge of your item and it should make it easy to remove.
Old Sep 20, 2011 | 06:49 PM
  #171
SilverZ350's Avatar
SilverZ350
Thanks I'll try this
Its not that easy when you have to wait 30 minutes between coats, by your third coat the overspray has pretty much hardened up. I'll try this and pull the tape directly after the last coat see if I have any better results. Although I like the idea of going around painted area with a razor. As long as the piece is not on the car.
Old Oct 5, 2011 | 05:58 AM
  #172
sry110's Avatar
sry110
Has anyone used the off-the-shelf black color Plastidip spray to re-do the window control console surrounds from the doors on the Z? Does the end result have the same rubberized matte finish as the stock pieces?
Old Oct 5, 2011 | 06:04 AM
  #173
moose350z's Avatar
moose350z
This?
Old Oct 5, 2011 | 06:19 AM
  #174
sry110's Avatar
sry110
^ Yep, the trim piece around the window controls on the door. You applied the off-the-shelf black pastidip to it? From that distance it looks pretty much like the OEM finish. How does it look and feel up close in comparison to OEM?
Old Oct 5, 2011 | 06:22 AM
  #175
moose350z's Avatar
moose350z
Yep. its a little bit more texturized but pretty close to oem finish.
Old Oct 5, 2011 | 06:26 AM
  #176
sry110's Avatar
sry110
Nice work! Looks like I found an activity for this coming Saturday morning : )
Old Oct 5, 2011 | 10:14 AM
  #177
moose350z's Avatar
moose350z
Thanks. Post pics in here when your finished.
Old Oct 5, 2011 | 10:27 AM
  #178
Waiz's Avatar
Waiz
Looks good moose, +1 on those pics after you're done sry.
Old Oct 18, 2011 | 12:43 PM
  #179
gregory71687's Avatar
gregory71687
You have to peel the tape while it is still wet
Old Oct 18, 2011 | 12:56 PM
  #180
gregory71687
Sorry I was a little late on that one
