help me figure wiring 06 headlights back to normal.
Old Apr 10, 2011 | 07:16 PM
bagged00's Avatar
bagged00
Default help me figure wiring 06 headlights back to normal.
so i got the car with 03 to 05 headlights and its an 06. i guess instead of disconnect the whole harness they decided to cut wires. so now i think i need a new harness as this one has no help.
headlight
no harness in this one
this one has all the wires cut.to the right of the plug runs into the headlight. the left of the plug runs out of a grommet in the picture after this one
hers the grommet
then the wires are cut along with 2 more blub wires
right now i have 03 05 headlights in like stated, im wondering if i can use harness outta them? i also found a 03 05 hid harness on ebay.
http://cgi.ebay.com/ebaymotors/03-05...Q5fAccessories
anyone know wheres else i can get one?
Old Apr 10, 2011 | 10:47 PM
gregom's Avatar
gregom
I got some 06's sitting in front of me. I can take pictures of a specific area if that would help you. I have an 04 Z and they plugged right in and worked fine without modification.
Old Apr 10, 2011 | 11:11 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
Easiest fix would be to go back to the origs it came with, they looked good and behaved fine, I am assuming...hell, i like the 05 headligjts better anyways, if nothing else, you can always throw and HID kit in if you want something different...just my 2cents
Old Apr 11, 2011 | 08:05 AM
bagged00's Avatar
bagged00
Bump Any idea guys
Old Apr 11, 2011 | 09:38 AM
KornerCarver's Avatar
KornerCarver
Here is a link that might be of help.................
https://my350z.com/forum/exterior-an...base-03-z.html
Old Apr 11, 2011 | 04:57 PM
gregom's Avatar
gregom
I'm sorry i'm really confused by your original post, I don't understand what you need.
But I have a complete headlamp harness from my 04 that I don't need anymore. I bought new 06+ headlamps that came with the harness. If you can use it you can have them, just pay the shipping. I'm not sure if the harness will work on 06+ headlamps. You may be able to get it working without too much trouble.
Old Apr 11, 2011 | 06:24 PM
bagged00's Avatar
bagged00
got one headlight done today. the wiring to convert from 06 lights back to 03 05 lights(my cars and 06) was hacked like a *****. so i basically had to re wire the whole headlight. took 4hrs for one headlight. now i have a new problem. the sockets for the lights are different from 03-05 compared to 06. i have no 06 sockets for my driver side headlight. seems they yanked the whole harness out of it.
gregom, i appreciate the help. i have an 03 -05 harness right now but the sockets dont work in the 06 lamps. so know i need a new 06 harness or some sockets one.
Old Apr 28, 2011 | 06:55 AM
spinviper's Avatar
spinviper
If my cay is 06 and I want to put 03 heAdlight on it, I will have to re wire the whole thing pluse buying a new socket ???
Old Apr 28, 2011 | 08:12 AM
bagged00's Avatar
bagged00
probably the easiest way would be figure out what wire does what on the 03 light. cut the pigtail off the 06 light leaving eough wire to splice back into the plug and the harness on the headligth if you ever wanna go back to the 06 light. then splice the 06 pigtail onto the 03 lights.
lapham3
Oct 7, 2022 03:15 PM
Dsowe
Feb 17, 2021 10:38 AM
350Z_Al
Oct 29, 2020 07:44 PM
Depravity
Oct 1, 2015 04:49 PM
JGee450
Sep 30, 2015 04:32 AM
