Part # for under-car splash guard
Old May 25, 2011 | 08:39 AM
ChrisStruttmann's Avatar
ChrisStruttmann
Default Part # for under-car splash guard
So I'm new to the nissan world and I need to replace the plastic piece that spans across the front underneath the car (I believe it's called a splash-guard) and connects the two front fender linings together. I'm having a little trouble understanding the nissan part lingo, does anyone know the part number? Is this it? http://www.courtesyparts.com/74811-c...-p-187913.html
03 Enthusiast Coupe
I searched for a few minutes and couldn't really find what I was looking for. All help is appreciated.
Thanks,
Chris
Old May 25, 2011 | 12:25 PM
beezee's Avatar
beezee
Yes, that is it. I am sure you could find used ones here on the forum. Just post in the want to buy (wanted) section. Lots of guys replace them with alum underpanels
Old May 25, 2011 | 01:29 PM
Yes. That is the piece that goes under the motor.
Old May 26, 2011 | 01:24 PM
kenttz's Avatar
kenttz
Yes that is the part you need which is pn# 75892-CD00A
Old May 26, 2011 | 01:36 PM
ChrisStruttmann
Thanks everyone... I didn't realize they made aluminum under panels... that's awesome.
Old May 26, 2011 | 02:21 PM
dcains's Avatar
dcains
$30 more gets you the Z Speed aluminum part. It'll last forever and you don't need to remove it for oil changes.
http://www.zspeedperformance.com/Exterior-Body_c15.htm
Old May 27, 2011 | 05:58 AM
ChrisStruttmann
That. is. beautiful. Just ordered one.
Old Jul 4, 2011 | 12:28 PM
WYZIWYG's Avatar
WYZIWYG
You guys are amazing. My front clips just broke off this weekend and I will definitely be ordering this as a replacement for the plastic OEM pieces.
Old Apr 23, 2014 | 05:27 PM
chriscoupe's Avatar
chriscoupe
Hi there,
Sorry to rehash an old thread, but mentioned above was the fact that the splashguard needs to be removed for oil changes. Is this confirmed? I have not yet changed the oil in my new car but plan on doing it frequently (and removing the stock guard would be inconvenient). The previous owner was driving it without a splash guard and I definitely want to get one, so is it worth getting stock or should I use the aluminum?
Thank you for your response!
Old Apr 23, 2014 | 09:37 PM
BranZ's Avatar
BranZ
You would have to remove the stock one every time you change your oil. That is why the aluminum one has a little access door you can use for easier oil changes.
Old Apr 23, 2014 | 11:01 PM
chriscoupe's Avatar
chriscoupe
Hmm ok, well maybe I'll look into those then. Thanks for the reply!
Chris
Old Apr 24, 2014 | 05:23 PM
Dan Garcia's Avatar
Dan Garcia
Default bolts and plug
Chris
you only have to remove two bolts and your oil plug to change your oil if you get the z-speed. check out the Fumoto drain valve that way you don't have to remove the oil drain plug.
Old Apr 24, 2014 | 05:29 PM
Dan Garcia's Avatar
Dan Garcia
Default drain valve
the drain valve makes it alot easier to change your oil
Attached Thumbnails Part # for under-car splash guard-2011_0630gallerybolts0004.jpg   Part # for under-car splash guard-2011_0630gallerybolts0005.jpg   Part # for under-car splash guard-2011_0630gallerybolts0014.jpg
Old Apr 24, 2014 | 05:44 PM
dcains's Avatar
dcains
I've got one of those, too.
Old Apr 24, 2014 | 06:00 PM
Dan Garcia's Avatar
Dan Garcia
I like mine very much, makes oil changes so easy.
Old Apr 27, 2014 | 05:46 PM
chriscoupe's Avatar
chriscoupe
You guys have convinced me, looks like I'll be buying one of these tonight! Thanks for the input.
Chris
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
_bit
Oct 2, 2015 07:49 AM
