55+ Watt HID kit
Old Jul 10, 2011 | 10:48 PM
blackdynamite33's Avatar
blackdynamite33
Default 55+ Watt HID kit
the stock 35 watt HIDs arent cutting it anymore. where i live there are ALOT of backroads with little to no lighting so i need slightly brighter lights. Does anyone have any reccomendations for any 55+ watt HID Kits?
Old Jul 11, 2011 | 01:25 AM
Spork's Avatar
Spork
Get 06+ headlights.
Old Jul 11, 2011 | 02:40 PM
gregom's Avatar
gregom
I don't think there are any 55W kits, but there are a few 50W kits. TRS sells one that looks pretty good, i'm thinking about trying it myself... If you do try it, let us know how it goes. You'll have to cut into your stock wiring from the headlamp to the ballast. My only concern is how the vehicles electrical system will respond to outputting 50W instead of 35W. You could potentially have problems with not enough power being supplied and the 50W ballasts not working, or several other electrical related issues....
http://www.theretrofitsource.com/pro...8vd35cmmkfvaa3
These would work the same regardless of 03-05 headlamps or 06+ headlamps.
Old Jul 11, 2011 | 02:46 PM
A-Town-Z's Avatar
A-Town-Z
DDM tuning makes a nice 55 watt kit. I have 8000k 55 watt system sitting in my garage. quality is great.
Old Jul 11, 2011 | 04:58 PM
ZS14RR's Avatar
ZS14RR
Seen some 55watt kits and the difference if very noticeable .. thinking about picking up a pair.
Old Jul 11, 2011 | 06:44 PM
blackdynamite33
@Spork: i was thinking about doing that, but i didnt want to spend that much money right now. The HID upgrade kits should only be a fraction of that cost.
@gregom: after more reasearch ive found the DDM Tuning 55 Watt HIDs. From what i found, they seem to be great.
@A-Town-Z: doesnt the 8000k come out more of a blueish-purple? i was thinkng of sticking with the 4300k, no more than 5000k. From what i see its the brightest and purest white you can get. Or does the fact that its 55watts modify the color of it some? Was it a clean "plug-n-play" kit or are there any modifications that need to be made? Lastly, different sources say our bulbs are D2R, some say D2S. which is correct?
Old Jul 11, 2011 | 11:07 PM
gregom's Avatar
gregom
I've heard good about the DDM... plus they are cheap I think so it's worth a try.
You'd have to do some research on the 50W HID systems... check out http://www.hidplanet.com/forums/. From what I recall the 50W will affect the color of standard 35W bulbs. If you use the bulbs supposedly designed for 50W, they will will be the color they are advertised as.
You won't find a clean plug and play kit, you're going to have to cut the two leads on the headlamp assembly to the ballast to power the 50's. That's where my concern comes in as to how the vehicles electrical system will respond to having to put 50W in stead of 35W, assuming they even will. I'm not really sure how the wiring in the Z works, ideally you would want to pull power directly from the battery with an external wiring harness.
Old Jul 12, 2011 | 06:31 AM
blackdynamite33
@gregom: check these out
https://my350z.com/forum/exterior-an...m-35w-hid.html
https://my350z.com/forum/exterior-an...w-upgrade.html
so it seems it can definitely be done without any problems. I'm going to look to around to see if there are any guides to setup of this specific kit in or cars. but im probably going to order this friday (payday)
Old Jul 12, 2011 | 06:38 AM
blackdynamite33
Directions on Install: The kit isnt much different so the directions should be about the same
https://my350z.com/forum/7720399-post38.html
Old Jul 15, 2011 | 10:40 AM
350fan4Life's Avatar
350fan4Life
Originally Posted by A-Town-Z
DDM tuning makes a nice 55 watt kit. I have 8000k hid bulbs 55 watt system sitting in my garage. quality is great.
DDM tunning has the worse customer service/shipping I rather pay more than wait weeks for a kit.
Old Jul 17, 2011 | 11:12 AM
A-Town-Z's Avatar
A-Town-Z
It only took a week to get here. And I the 55 watt 8k look like 35 watt 6k.
Old Jul 19, 2011 | 03:46 PM
gregom's Avatar
gregom
Get some 5000K 55W bulbs and try again... some comparison pics would be nice if you can.
Old Jul 23, 2011 | 07:51 AM
misterniceguy's Avatar
misterniceguy
Ordered a kit from DDM for my truck and it got to my door in 6 days. Ordered on Sunday and came on Saturday. Can't say anything for actual quality yet, but shipping wasn't bad.
Old Jul 24, 2011 | 09:24 AM
kcalvano's Avatar
kcalvano
I have an '04 enthusiast. What bulb type are you guys ordering for the DDM kit?
Pleask
Dec 21, 2021 03:17 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
