Painting 06+ Headlights
Old Sep 12, 2011 | 11:28 PM
leo_giovani619's Avatar
leo_giovani619
Default Painting 06+ Headlights
Ok I want to bake my headlights for a lens retrofit.I have done it before with
03-05 lights but in a different oven (ex girlfriends) as in the heat from the oven comes from the top.
Now my oven's heat comes from the bottom?
Can I still do it?
Just put cardboard and thats it?
I dont want to mess up the $800 lights I just bought
Im just being cautious.
Thank you for your response.
Old Sep 13, 2011 | 12:13 AM
Itzcashew's Avatar
Itzcashew
Wet a piece of cardboard and place a wet rag on top of it. keep the light away from the sides as it will melt the plastic
Old Sep 13, 2011 | 12:27 AM
leo_giovani619
What do you mean as in keep the light away from the sides?
And what exact temp and time would be ideal for the open and closing of headlights?
I havent done this mod in about 3 years.
Thank you.
Old Sep 13, 2011 | 08:36 AM
bmccann101's Avatar
bmccann101
i believe its 250 degrees for 10-15 minutes.
I have read that in places it several times.. have mine done professionally tho.. yal r brave.
Old Sep 13, 2011 | 09:22 AM
gvulakh's Avatar
gvulakh
A heat gun to seperate the lens from the housing is an option as well.
Old Sep 13, 2011 | 09:52 AM
bmccann101's Avatar
bmccann101
good intentioned advice im sure, and maybe someones pulled it off that way.. but most likely a very bad idea unless you a total wizard w the heat gun.. the oven radiates the heat in a far less focused beam of heat.. thats why the ovens what you really want to use. imagine cookig a chicken w a heat gun.. versus puttin it inthe oven.. you get the picture..
Fawk it, im gonna cook a chicken w a heat gun now. haha.
I see 5 out of 10 ppl who would use a heat gun melting their lenses w hot spots.
Do not use wet cardboard when re sealing them in the oven. Just use shorter periods in the oven. Ive also heard of adding wet cardboard at that stage will cause evaporation and will likely fog the lenses in most cases.
Old Sep 13, 2011 | 10:58 AM
gvulakh's Avatar
gvulakh
I actually used a heat gun on an 05 head light that was about to get scrapped because of a broken tab. Wanted to practice before I disassembled my 07 head lights.
The heat gun method worked but you do have to work very carefully and pay attention.
Old Sep 13, 2011 | 11:07 AM
Waiz's Avatar
Waiz
I don't think the oven element being on top or bottom matters, it still will be the same amount of heat inside.
Edit:
This is the thread that you should also reference that contains all the relevant info:
https://my350z.com/forum/body-interi...eadlights.html
Justin100
Nov 25, 2021 06:26 AM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
