spoiler installation
Old Dec 27, 2003 | 07:37 AM
iriee's Avatar
iriee
Question spoiler installation
wife just got me a spoiler for my silverstone. dealer wants 150.00 to install. is this something an average dummy like me can do or do i give up the 150? are there holes to be drilled?? any help would be great. thanks!
Old Dec 27, 2003 | 08:25 AM
350zluvr's Avatar
350zluvr
I do believe there are holes to be drilled as well as some type of glue to be applied. I am the average "dummy" and I personally would not want to take that on myself just because I don't know the first thing about applying a spoiler. All the alignment to make the spoiler fit just right makes me nervous, I just know that I would mess something up. Check around for pricing though.
Old Dec 27, 2003 | 10:48 AM
Mapleleaf's Avatar
Mapleleaf
Default Rear Spolier
If it's the factory piece then their should be a templete to attach to the back trunk of your 350 , I drilled holes to attach the piece as well as new trunk cylinders to replace the factory one's some have used tape but I wouldn't trust tape alone, if your not sure about doing it safely yourself then bite the bullet and get it done by a professional
Old Dec 27, 2003 | 12:25 PM
Z YA LTR's Avatar
Z YA LTR
Is it an aftermarket spoiler? If so, do you already have the factory spoiler installed? If you do, the aftermarket spoiler might use the same holes.
--Josh
Old Dec 28, 2003 | 12:56 PM
wakaZ's Avatar
wakaZ
I bought the factory spoiler from another user on this forum, and wanted to do it myself.
Install is not too bad, just make sure the "template" is set properly. No kinks, very flat.
When removing the large panel, some of the plastic clips broke, but inside the factory kit they had a bunch of replacement ones.
When drilling, I used a vaccum to suck the shavings (while drilling). Also, stuck a small flex magnet inside all the holes to make sure to remove all metal shavings, then vaccumed again.
Affter all holes were drilled, I painted all the bare metal areas where drilled.
Make sure to remove the double stick tape after you put the spoiler on BUT before putting on the nuts.
Make sure to use the factory struts that come with the kit. The stock ones don't work.
Overall, not too hard to do, just kinda scary at first (the first hole) but I'm glad I did it.
Old Dec 28, 2003 | 01:04 PM
MATIX's Avatar
MATIX
You dont even need to drill holes, I attched my factory spoiler with double-sided tape, took me 5 minutes.
Old Jan 2, 2004 | 05:05 PM
djbit's Avatar
djbit
MATIX, the factory spoiler has 2 screws, did you cut these off to just tape it up ?
Old Jan 3, 2004 | 02:23 AM
MATIX's Avatar
MATIX
I didnt even see two screws....
Old Jan 3, 2004 | 06:35 PM
Kenyon's Avatar
Kenyon
than you probably have the factory replica wing.
Old Jan 3, 2004 | 08:33 PM
MATIX's Avatar
MATIX
It's not a relica, it came off of my freinds track model and it has the oem part numbers on it
Old Jan 3, 2004 | 09:44 PM
mofoz's Avatar
mofoz
you really are only holding down your spoiler with double sided sticky tape? Isnt there going to be a decent amount of downforce applied onto the spoiler? I could be wrong, but im just wondering.
Old Jan 3, 2004 | 09:49 PM
MATIX's Avatar
MATIX
The 3M double sided tape is made for applications such as this so it is pretty sticky, and holds the wing on well.
Old Jan 3, 2004 | 11:00 PM
Ryder32's Avatar
Ryder32
yeah, i have my spoiler held down by double sided tape...only use 3m tape..that's it...
Old Jan 3, 2004 | 11:51 PM
kzshin's Avatar
kzshin
some spolier can be held just by 3M doubl sided tape. My cousin;s Brabus spoiler for his MB E320 is tape on also.
Old Jan 4, 2004 | 12:12 AM
Ultimateone's Avatar
Ultimateone
double sided tape here also, but Im getting a new wing soon
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
